Is ther any reason to leave the A/C pump on
  • 1953 Views
Offline Black Zuk
  • 77
  • Top Down Cruse around and play in the dirt.
« on: April 17, 2009, 11:40:10 AM »
I have a 87' 1.3 that has been newly acquired. I look under the hood and there is an a/c pump hooked up? Is there any reason the leave this in? It is odd considering it's a soft top and all.
88' Samurai, Throlly Exhaust and Calimini cam so far
Re: Is ther any reason to leave the A/C pump on
« Reply #1 on: April 17, 2009, 01:56:55 PM »
Does the AC blow cold air?  If not you might want to convert it to on-board air.
« Reply #2 on: April 19, 2009, 10:16:35 AM »
is there any guides out there for doing this?
'99 Chevy Tracker 2.0L 4WD
'01 Daewoo Nubira 2.0L 4dr
'04 Saturn Vue 2.2L AWD
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #3 on: April 19, 2009, 09:53:54 PM »
I believe there is a writeup on Ack's FAQ on how to do it
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline rascott
  • 669
  • 15
« Reply #4 on: April 20, 2009, 05:29:45 AM »
my sidekick('89) came with a/c also.
convertible. go figure.
it worked fine, but i have removed most of it.
question: what all is inside the ducting/fan stuff behind the glove box? i've never been in there and am considering pulling that radiator part out if i can without causing big headache like removing dash or......
Offline Black Zuk
  • 77
« Reply #5 on: April 20, 2009, 06:23:34 AM »
Well it dose still work.(checked it this weekend) and I think having on board air is a good idea. (also needed this weekend, I had to pack a compressor). so are there parts i need or what, I'm sure it's not just adding fittings.
Offline locjaw
  • 2045
  • 22
« Reply #6 on: April 20, 2009, 07:04:41 AM »
the radiator thing (AKA the heat exchanger) is pretty easy to pull out. it is in the section between the fan and the heater core. you will need a replacement duct from a non-A/C sidekick to put back in the hole
Offline rascott
  • 669
  • 15
« Reply #7 on: April 20, 2009, 09:27:52 AM »
thanks- now i know how to approach it.
richard
« Reply #8 on: April 21, 2009, 09:59:46 AM »
http://www.acksfaq.com/ac-conv.htm
On my SJ I pack that little read air compressor you can pick up a Napa.  It has worked without fail for years.
