Best way to remove rust?
  • 1810 Views
« on: April 09, 2009, 07:15:35 AM »
I just bought a Sammy and it's got alot of surface rust on most of the underside. I want to clean it up so it both looks nice and lasts longer. I'll be removing the axles, springs, etc. anyway, in preparation for a SPOA lift. I'll be doing the work in the back yard. Are sandblasters as messy as I assume they are? I've never used one... don't even know if they make portable ones that I could rent/buy.
What's the best way to remove the rust?
Re: Best way to remove rust?
« Reply #1 on: April 09, 2009, 05:59:35 PM »
You can pressure wash it with soap & water, or steam clean it - then paint it with a rust neutralizer & follow up with an undercoating. Sand blaster would work - but again - follow up with undercoating, and yes - sandblasting is as "dirty" as you think it is. Pretend you're on a beach with 100 MPH winds, and someone dropping sand from the sky.
« Reply #2 on: April 09, 2009, 06:02:19 PM »
Thanks. I'll see how bad things are when I start taking things apart.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #4 on: April 10, 2009, 09:12:15 PM »
Ack
xoloski
« Reply #5 on: April 11, 2009, 07:24:44 AM »
Check out evap-o-rust.
I've seen the results at:  http://www.evaporust.com/
The looks impressive.
I've never tired the product myself.
There is on rust here in southeast Arizona, unless the vehicle came from where I grew up in northern Minnesota where, on a quite evening, you can sit outside and hear the cars rust.
« Reply #6 on: April 11, 2009, 10:36:10 AM »
POR has been a popular choice for years.
