weber problems
  • 1125 Views
Offline whitestanger
  • 18
weber problems
« on: April 08, 2009, 04:36:10 PM »
Just installed a weber 32/36 and it will barely idle with the choke closed but if i hit the gas it dies. If i open the choke it won't even start. I capped off all unused vacuum ports and i capped off my egr valve. If i dump fuel down the carb it will run until the gas burns up then dies. I pulled the fuel line off the carb and cranked it over and lots of fuel comes out of the line so its not the pump. I am out of ideas any help is appreciated.
1988 1/2 Samurai
6" breeze Industries SPOA lift & trac bar
4" Body Lift
33"x13.50" Super Swampers on off set 15" rims
5"-10" drop shackles front and rear
Skyjacker Shocks
Russel stainless steel brake and fuel lines
Fuel cell
10 000  winch front
3000  winch rear
custom bumpers
Offline rascott
  • 669
  • 15
Re: weber problems
« Reply #1 on: April 08, 2009, 06:15:38 PM »
make sure you haven't overlooked some vacuum leak.
is this a new unit(w/mounting instructions?)?
perhaps some crap in the idle jets, but it should still be able to run on the mains(sorta at least) w/ throttle open(i think).
these things are pretty simple, but initial setup instructions are important.
try this:
pull the idle jets to confirm they are clean( are you running a fuel pressure regulator?), jets probably #60?.
back out idle screw 'till off the throttle lever(w/choke off high idle cam), then screw in 1-1 1/2 turns.
gently screw mixture screw till it stops, then back out 2 turns.
if all else is good- it should run(probably idling high).
further adjustments would follow, but that should be close enough to know that it's working ok.
  • 18
Re: weber problems
« Reply #2 on: April 09, 2009, 04:31:38 AM »
It is a brand new unit but i dont have a regulator on it but i think the problem is that it is not getting enough gas. I heard that the factory pump gives it to much gas but i am not getting enough into the carb.
1988 1/2 Samurai
4" Body Lift
Skyjacker Shocks
Fuel cell
10 000  winch front
3000  winch rear
custom bumpers
Offline rascott
  • 669
  • 15
Re: weber problems
« Reply #3 on: April 09, 2009, 08:41:50 PM »
i used the stock fuel pump and had no problem, but put a regulator on it pretty quick as i was afraid it might be too much at high revs.
used an empi regulator 'cause it was cheap and i've used them successfully in the past.
since this was a new unit, you got the tuning scrip, right?
 they(redline/weber) have a tech service for a short time(i've never used), but you might open the thing up and see if anything weird is happening w/the float settings or whatever.
you're sure |removethispart|@ vacuum leaks?
  • 18
Re: weber problems
« Reply #4 on: April 10, 2009, 06:50:28 AM »
I adjusted the floats and i drained my gas tank and cleaned it out put some 94 octane in it and i put a fuel regulator on it and it seems to be working fine now. Thanks for the help
1988 1/2 Samurai
4" Body Lift
Skyjacker Shocks
Fuel cell
10 000  winch front
3000  winch rear
custom bumpers
