tracker 5.83s on 35s paging mike hagen
  • 10 Replies
  • 4364 Views
Offline mersingt
« on: April 06, 2009, 01:38:20 PM »
ok I just got a set of 5.83s with a spool and Im looking at upsizing form my 31s to a larger set..intially I was going to run 33x1050 bfg mt's but I saw hagens rig on 5.83s and was wondering if it would be able to run around on 35s...Ive got a 16v 2 door with 5 speed (3 inch bodylift and 4 door springs)
my front 4 door springs are sagging so i suppose a 1.5 or 1.25" spacer in front and a 1.75 or 1.5 in rear will suffice along with sufficient trimming
96 geo tracker 2 door
31" tsl radials
3 inch calmini
4 door springs
Re: tracker 5.83s on 35s paging mike hagen
« Reply #1 on: April 06, 2009, 02:54:34 PM »
What do you mean by "could be able to run"  ??? I've made it through the 'con on 35" tires and 4.88 gears & an auto :o Runs like a TURD on-street though. There's not much difference between a 5.125 and 5.83 (~14%), should get you corrected to a 30/31" tire as far as stock gearing. Running 35" tires would be ~14% bigger than 31", so... it should act approximately like running 31" tires with stock gearing (Turd). Carry a whole set of spare 1/2 shafts, CV's and rear axle shafts. You're going to need them with stock axles & 35"ers.
Offline mersingt
« Reply #2 on: April 06, 2009, 02:56:42 PM »
35s is mainly a dream...In reality thought 33 1050s are what I want to run...
31" tsl radials
3 inch calmini
4 door springs
Offline zukisidekick
  • 85
« Reply #3 on: April 06, 2009, 03:49:04 PM »
I'm running 34" LTB Swampers on my rig, and I will tell you that just adding 5.83's won't be enough.   If you're going to wheel your rig, you'll need some transfer case gears, unless you enjoy smoking clutches.  You'll also need to add a bit more lift and/or trim back your fenders.
I'm running a combination of  5.38 gears, 4.24 t-case, and extensive mods to the suspension and drivetrain.....
You can do it, but be prepared to mod your rig.
Offline mersingt
« Reply #4 on: April 06, 2009, 04:11:48 PM »
well tcase gears wont be able to get here for awhile...It does just fine on 31s with 5.13s (and thats with heavy swampers) so I think It would be alright on 33/1050 bfg mts
31" tsl radials
3 inch calmini
4 door springs
  • 85
« Reply #5 on: April 06, 2009, 06:00:52 PM »
I had a similar setup to yours  (31" Swampers, 5.12, 5 Speed), and it was okay, but when you step up to 33-35", it's a big difference.
« Last Edit: April 09, 2009, 03:45:14 PM by zukisidekick »
Offline RACER X
  • 383
  • zuki or die!
« Reply #6 on: April 06, 2009, 08:52:02 PM »
F-em all and sell me the 583s ?????
98 kick
Offline Amilla
  • 1076
« Reply #7 on: April 08, 2009, 06:58:41 AM »
4.10 R&p, 6.5:1 T-case, with 34 LTBs.  High range is useless off road, unless just jamming along on a trail.
Gearing may bring you back to "stock" but only more power can make up for the loss due to rotational mass. A doubler would make things right, and give you lots more gearing options.
Amilla
Offline bzzr2
  • 1011
« Reply #8 on: April 08, 2009, 07:33:55 AM »
i just went from a 31x9.5 swamper to a 31x10.5 ssr, which are actually 1.5inches taller, 2inches wider and according to specs 10lbs heavier per tire and holy shard what a difference, very noticeable on further power loss..
09 taco reg cab short box 4x4
« Reply #9 on: April 09, 2009, 09:31:22 AM »
ive got 35's with 4:11 gears and a 1.3 i just drive in low in town lol
Offline bandit86
  • 1641
  • elv8rguy
« Reply #10 on: April 12, 2009, 07:56:00 AM »
I ran 33x12.5 on a 2door 5 speed, never had a problem offroad.  with the 35s and 5.83 youre ok
it will act like 30s on a stock drivetrain
