Newer Tracker wheels vs. mine - backspacing/offest?
  • 1780 Views
Offline Z71Edge
  • 87
« on: April 06, 2009, 10:41:05 AM »
Does anybody know how much offset/backspacing these tracker wheels have versus the ones I have on my 93? Trying to figure out if they will stick out a little further or not...if not, I could always use some 1" wheel spacers i guess...
93 Tracker, 1.6L 5spd, 235's on stockers for now...
Offline Z71Edge
  • 87
Re: Newer Tracker wheels vs. mine - backspacing/offest?
« Reply #1 on: April 07, 2009, 08:47:53 AM »
guess nobody knows  ???
Offline fuzzy1
  • 350
« Reply #2 on: April 07, 2009, 10:49:56 AM »
I don't know for sure offhand if the factory alloys are the same as the steel, but since the wheels are off you can check easy. Set a straight edge on the inside of the rim & measure (perpendicular) to the inner wheel mounting surface. Then put the straight edge on the outside & measure to WMS... Adding the two = rim width, 2nd number is your backspace.  1st measurement is how much 'tucks in' to the wheelwell, 2nd is how much 'sticks out'. Stock steel are 15x5.5 & iirc 1.75"  b/s. hth
edit: you'll need a 15" straight edge so you're not measuring the tire width too...
Fuzz
« Last Edit: April 07, 2009, 11:00:55 AM by fuzzy1 »
Non Illegitimi Conterat
