If you aren't getting spark, it has nothing to do with where things are... The distributor gets power from the electrical system then sends a pulse to the coil which then fires off spark back to the distributor cap... More than likely your distributor is dead... But, make sure you check the wiring closely between the distributor and coil first... Make sure there are no broken wires...
