I have an 86 sammy (daily driver), and it has developed a rough idle. I am going to check for vacuum leaks, idle mixture adjustment, plugs, wires, Dist. cap, etc. this weekend, but the carb looks like it is in need of a rebuild. So, I am looking at the weber conversion, as it seems to be a better setup from everything I have read. The truck drives well and has plenty of pep for a 1.3 and has no hesitation.
I do have a couple of questions about the weber conversion for those of you who have done one. What do you do with all the emissions stuff and electronic controls from the OE carb? I would think that you would just unhook them and seal them off, but I want to make sure. I saw that the conversion comes with new brackets for the throttle linkage, has anyone experienced any difficulty with hooking up the throttle?
I have seen two kits available for the weber conversion, one with an adapter to use the stock intake, and another with a square filter that fits on top of the carb. I am leaning toward the stock intake adapter since it is my daily driver and I drive it all winter here in Iowa, but I would like your thoughts on which is better.
Last, is there a direct EFI conversion for the 86 1.3L? And if there is, is there any advantage to going to EFI over Carb since I really don't take it on the trails?
