sorry for the delay,i run a tracker/sidekick, UK Vitara, with the calmini combo lift and 33.12.50s Wrangler MTR . couple of other bits
picture on the twist off comp a month ago, slightly cheated i think as rear wheel washardly touching the ground giving me a score of 906. previous score was 872.
you can see some more on my site ,,that needs updating as my ISP took back the webspace i wasnt paying for
http://www.markyb.co.ukMy  tracker/vitara, was built in Ireland which may explain why i seem to have variants to others.its a 1990 spec but register as a 96  at full travel on the twist off ramp my drive shaft still have around 2 inches of clearance before hitting the wish bones,  I was hoping to find a medium as not to put stress on the cv by compounding the angle to much . but try to gain an extra inch or so.
The ome struts maybe the way forward but drop the spacer down to 1 inch or so , maybe not worth all the bother to gain a little more travel.
May upgrade the rears and have the articulation there and be happy. :-)
Cheers for your help
