smoke in the air box
  • 1861 Views
Offline whitestanger
  • 18
« on: April 01, 2009, 04:35:22 PM »
Its a 88 samurai with the 1.3L carb engine. I was out for a run and when i pulled it back in the shop there was smoke comming from under the hood. I opened the air box and it was full of smoke. What would cause the air box to fill with smoke like that.
1988 1/2 Samurai
6" breeze Industries SPOA lift & trac bar
4" Body Lift
33"x13.50" Super Swampers on off set 15" rims
5"-10" drop shackles front and rear
Skyjacker Shocks
Russel stainless steel brake and fuel lines
Fuel cell
10 000  winch front
3000  winch rear
custom bumpers
Offline norcalwreckchaser
  • 128
Re: smoke in the air box
« Reply #1 on: April 01, 2009, 05:09:06 PM »
Did you observe any odor with the smoke, oil,fuel/gas,coolant?
Norcal
Sold 7/10 :(
  • 18
« Reply #2 on: April 01, 2009, 05:28:10 PM »
Norcal
  It smelled like coolant to me
1988 1/2 Samurai
4" Body Lift
Skyjacker Shocks
Fuel cell
10 000  winch front
3000  winch rear
custom bumpers
  • 128
« Reply #3 on: April 01, 2009, 05:39:33 PM »
Check your hoses, there is a small coolant line under the intake which is kind of out of site. Or you may have a head gasket about to blow. Assuming you are running a stock intake, and there was alot of steam or smoke under the hood, your airbox would suck it in.
Norcal
Sold 7/10 :(
  • 18
« Reply #4 on: April 02, 2009, 03:25:24 PM »
I ran it again today i didn't have any smoke under the hood. It ran fine for 20 minutes then it didn't want to idle any more.
1988 1/2 Samurai
4" Body Lift
Skyjacker Shocks
Fuel cell
10 000  winch front
3000  winch rear
custom bumpers
  • 128
« Reply #5 on: April 02, 2009, 03:30:58 PM »
Have you checked your radiator to see if you have any oil in it, if so I think you have a blown head gasket.
Sold 7/10 :(
