Automatics anyone?
  • 2082 Views
Automatics anyone?
« on: March 29, 2009, 04:32:53 PM »
Just wondering if anyone still uses the factory auto trans in their offroad buggies? Or are they too weak to use with suspention mods, taller tires and lower gears?
Offline Armour
  • 360
Re: Automatics anyone?
« Reply #1 on: March 29, 2009, 08:01:23 PM »
I am running and auto! No problems here. 5.12 gears. 4.24 t case and 33's.
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: March 29, 2009, 08:30:06 PM »
Same here, I've been pounding on mine offroad for about 3 years now >:D
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline Spitfire Rick
  • 123
  • fun lovin criminal
« Reply #3 on: March 30, 2009, 06:45:42 AM »
Ive got the OD auto dual transfercases 462s &35" boggers  & has held up for 2 years
If I have to understand don't bother explaining
« Reply #4 on: March 30, 2009, 07:02:05 AM »
I'm running the stock 3 speed w 5.12 diffs, 4:24 tcase, & 31"MTs for 5 years in the trail rig.  I think I've had to replace the vacuum modulator valve.
Just had the 3 speed auto in my (seldom wheeled) daily driver rebuilt at +150K miles.
« Reply #5 on: March 30, 2009, 12:35:15 PM »
4-speed pushing a 4-door & 35" tires. That's about as much "load" as you can put on a trans & mine works like a charm. Don't need crawler gears 'cause the torque multiplication is the goods. If you run an auto, there's a few things to keep in mind: No bump-start = run a dual battery system (or have one of those "charge packs") & carry a spare starter (ask me how I know). And, RUN A LARGER TRANSMISSION COOLER, or a second trans cooler in-line. It doesn't need to be a monster, but the stock cooler will be inaddiquate for rock crawling, or larger tires. Torque convert's going to be working harder - which is totally fine as long as it's supplied with cooler oil (I believe around 170*). You can re-use the old trans cooler as a power steering fluid cooler (also needed with larger tires), or an engine oil cooler.
« Reply #6 on: March 30, 2009, 03:06:36 PM »
Ditto, and a turbo too.
« Reply #7 on: April 03, 2009, 06:19:46 PM »
 Thanks for all the input! I figured it would work ok, after I read that it was an auto trans made from a Toyota, cant remember right now where I read that though.
« Reply #8 on: April 04, 2009, 01:26:30 PM »
It's probably either a Chevrolet or an Aisin. I know Aisin's can be adapted to work with Suzukis:
http://www.pirate4x4.com/forum/showthread.php?t=716069&highlight=71
http://www.nuceng.ca/bill/volvo/database/tranny.htm
