Aftermarket Seats for Tracker?
  • 2706 Views
Offline holman
  • 42
« on: June 07, 2005, 02:39:53 AM »
I'm looking to buy a set of aftermarket front seats for a 1995 Tracker.Any suggestions on makes and models that would work well.Thanks.
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
Re: Aftermarket Seats for Tracker?
« Reply #1 on: June 07, 2005, 11:02:16 AM »
I have been doing some research also.  If you do a "seat" search back about a year you will find some answers.   I have looked at APC brand seats at summit racing on the web and ebay etc.  They are not the exact same bracket dimensions but I've been told by custom shops that you can have mounting brackets made easily at any custom or machine shop.   Ive been told you can fit Neon seats directly in replacement of stock seats.  Also that the Suzuki LSI seats are  better than the stock one piece models.
Ive sat in some APC seats and they feel real good.  If I could get them to fit I will probably go with them.  The price is real good also.
good luck with your search
Offline explosivo
  • 3157
« Reply #2 on: June 07, 2005, 11:04:50 AM »
LSi seats are the tits... too bad the set I had in my parts Tracker were all torn to hell, or I would've swapped them to mine ;D
omghi2.us[/url]
Offline 1bigtracker
  • 3409
« Reply #3 on: June 07, 2005, 11:59:28 AM »
LSi seats in mine, love them!  1o times better than stock no options seats.  my .02
stu
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #4 on: June 07, 2005, 12:46:38 PM »
stu
that's the answer i was looking for in regards ot lsi vs. stock high back version.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #5 on: June 08, 2005, 03:06:49 PM »
In my silver Tracker I went a slightly different direction when I replaced the seats. I found a pair of seats in the junkyard from an X-90. They are just like LSI seats, but feel a little more supportive. The only drawback to them was the risers on the base of the seats. They were 2" shorter(closer to the floor) than stock Tracker seats. I did some seat surgery to them and ended up with stock Tracker seat bases/bottom frame and tracks and X-90 seat backs, recline levers and upholstery. They work really well and are VERY comfortable! And with the separate headrest design, they work with 5-points! ;)
