S/R with RUF ??
S/R with RUF ??
Mac0
91
S/R with RUF ??
August 20, 2004, 12:21:26 PM »
Can you use the Calmenie Shackle reversal with Rears up front on the old Samurai ?? Then use stock rears on the back with extended shackles
Thanks
TomKat
211
Re: S/R with RUF ??
August 22, 2004, 01:22:13 PM »
Your shackles will end up close to parallel with the ground due to the longer spring. Not a good setup....
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Mac0
91
Re: S/R with RUF ??
August 23, 2004, 07:16:03 PM »
OK -- thanks for the reply. I need to do something about the ride on this little warrior ----
Crow_Horse
29
Re: S/R with RUF ??
Reply #3 on:
August 24, 2004, 10:34:01 AM »
Yes you can as I run this. The springs required drilling the locating bolt so the axle is moved forward a bit.....
The shackles are nearly vertical in doing this........
All Good Medicine,
Crow
Crow_Horse
29
Re: S/R with RUF ??
Reply #4 on:
August 24, 2004, 10:39:45 AM »
All Good Medicine,
Crow
TomKat
211
Re: S/R with RUF ??
Reply #5 on:
August 25, 2004, 05:03:37 AM »
Ahah! I stand corrected. Good work, Crow, as always. Must be an old pic, or did you get the body fixed already?
Last Edit: August 25, 2004, 05:04:44 AM by TomKat
Crow_Horse
29
Re: S/R with RUF ??
Reply #6 on:
August 25, 2004, 08:18:40 PM »
Sad to say that it's an old pic...
All Good Medicine,
Crow
