Calmini Skid Plate Installation Help??
  • 10 Replies
  • 2298 Views
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« on: August 24, 2004, 11:05:00 AM »
I have read the instruction sheet I got with the transfer case skid plate and still not sure if I have it right ???
Can anyone answer or have pics of them fitted?
I understand how the Z bracket craddles to the rear round crossmember.
But in the instructions it says to line up the front with threaded bolts holes in the transmission cross member and bolt up?
My transmission cross member does not have any spare bolt holes?
I thought that the front of the transfere skid plate would sit on the transmission cross member lip and when you fit the transmission skid plate it bolts up to the transfer case skid plate then holding both in place pulling down on the lip?
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Re: Calmini Skid Plate Installation Help??
« Reply #1 on: August 24, 2004, 12:30:22 PM »
Thats just a FUBAR. On my 95 Tracker there is no Threaded holes either. There is a bracket you can bolt it to if you have a nut.
The rear Z-bar is overlapping the center cross-bar by a hare.
« Last Edit: August 24, 2004, 01:00:30 PM by trickker »
Offline suzukiboyoz
  • 194
« Reply #2 on: August 24, 2004, 03:24:56 PM »
Thanks for that HotRod I looked on your web site and saw your pics of the skid plates helps a little more.
I was under the car last night and was looking for the bloody holes.
Thought I was going to have to drill and tap.
Your brother has a nice bike too.
They are very quick ;D I have a 2001 K1 model Red/Black/Silver
« Reply #3 on: August 24, 2004, 03:42:21 PM »
My little bro wussed out and is trying to sell it. Tooo fast for in-town riding. Besides, He already got a ticket on it in the first few days he rode it.
 Glad ya got it figured out. I drew up a pic but couldn't get it posted :-/   I put spacers between the skid plates ant the other bracket as to not squish them together.
« Last Edit: August 24, 2004, 03:43:28 PM by trickker »
Offline suzukiboyoz
  • 194
« Reply #4 on: August 25, 2004, 12:50:52 AM »
HotRod sent you a email with a few pics of the skid plates I tried to loosely fit today.
I think I am on the right track, I just did not realize how bent my cross member was.
Dave
« Reply #5 on: August 25, 2004, 03:36:29 AM »
"WOW" you hit that cross-member hard :o
It might straighten up a bit if sitting on all 4 just enough to get it together. I'll post your pics.
That cross member is bent really far back. If you do have another one you mighj want to replace it now and then install your skids.
« Last Edit: August 25, 2004, 03:55:19 AM by trickker »
Offline suzukiboyoz
  • 194
« Reply #6 on: August 25, 2004, 04:44:28 PM »
It was a nicely placed stump in the middle of the track.
The rear skid does not sit on the lip?
Is that what you mean but the 1st photo (hangs below) then bolt up to the middle cross member?
Offline suzukiboyoz
  • 194
« Reply #7 on: August 25, 2004, 05:20:50 PM »
Should have said skid pate?
« Reply #8 on: August 25, 2004, 05:56:13 PM »
From what I have noticed is if the skidplate catches the bottom of the cross member it'll stop the skidplate from being pushed up if you hit another stump ;D
Anybodyelse like to chime in?
I put steel spacers between the T-case skidplate and the upper bracket in witch the bolts go through to stop the upper bracket being pulled down.
« Reply #9 on: August 25, 2004, 10:09:06 PM »
I trashed a couple of crossmembers before I got my Skid Plates fitted, had to cut them about cos the side metal was bent back over the bolt heads. It looks like you have the same crossmember I have, it catches much easier than the earlier type (the one with the bolt holes) I modded the cross member with an inverted U section with two nuts welded in place. have a look on my site under mods, skids
http://www.rhinoman.fsnet.co.uk
The skid plates spread the impact across the crossmember and prevent the lip from catching and digging in.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #10 on: August 26, 2004, 12:00:21 AM »
Man that pic there was no rust must be nice :P
01 GRAND VITARA
