how do you replace the body studs?
  • 999 Views
Offline truk1
  • 44
« on: March 16, 2009, 05:55:52 PM »
is there away to replace the factory body studs? mine are very rusty so i figure with my luck they will break when i do my body lift. im thinking i can use a hole saw from the floor to open up over the stud pocket. but i have not looked and figure you guys would know  thanks matt
91 sidekick 4x4 header,
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: how do you replace the body studs?
« Reply #1 on: March 16, 2009, 07:24:47 PM »
Cutting and welding would be the only way that I can think of.  A holesaw might be a good idea if you could do it from up top, then weld a bolt to a large plate/washer, and weld it back into place.  Maybe keep the bolt as removable so that if it rusts again, you can replace it.
1993 4-door Sidekick
4.24:1 t-case
Offline ToyYoda
  • 226
« Reply #2 on: March 17, 2009, 06:40:52 PM »
I hate the way Suzuki attached body to frame on X90s & Sidekicks."Dumb at best " In the UK they talk about this problem on a large Suzuki site. Cut through the floor & remove the problem body stud. Weld in a plate to cover the cut out floor area & build it back with through bolt like a Toyota/Nissan truck ect. Far better & no noise when off roading/twisting. Yes, Suzuki got the two front body mounts right.
