What air pressure are you guys running on-road in :
225/75R15 = ?
235/75R15 = ?
30 inch = ?
32 inch = ?
Thanks.
I am '01 GV H25, stock but for BFG AT T/A ko's 215/70/16's, K&N in the air box, Magnaflow secondary cat and muffler with 2.25 inch pipe, new KYB stock struts and gas-a-justs. (Wow, did that raise my COG!)
Stock pressure is 26 for the original Duelers. I run 34-36 road for mileage, and even tire wear. They are 6 ply with 3 ply sadewall. If I get into deeper snow or a bit of mushy roadbed (no deep sand or mud, and no rock ckimbs), I can drop that to whatever is nec, but NEVER lower than 24 as the stiff tires don't do well below that, at least so far. If I am going off road, I always take my air tank.
At 36#, the ride is harsh on many Oregon roads and highways, but the new suspension parts make it hard to determine attribution right now. Obviously much better dampening of spring travel/compression.
I should point out that as the tires wear and stretch, the pressure issue changes somewhat with the increased flexibility. My tires are new second set, near 45k miles on first ones.
More than you asked for.
Pat
