86 samurai will not start
  • 1954 Views
Offline wyo-hunter
« on: March 07, 2009, 05:10:28 PM »
I have an 86 samurai , and I recently installed a weber carb on it because the stock Hitachi was only getting about 13 mpg. While I was trying to get it to run with this, it quit running altogether. I have no spark at all. New coil, tested the ignition module a' la Chiltons manual, still nothing. Maybe ECM problem? Any ideas?
"Those who will not be governed by God, will be ruled by tyrants."  William Penn
  • 6544
  • 64
Re: 86 samurai will not start
« Reply #1 on: March 07, 2009, 05:17:38 PM »
Does your rotor spin on the distributor when you crank the engine?
Offline wyo-hunter
« Reply #2 on: March 07, 2009, 07:59:43 PM »
Yes, in order to test the module I had to take the distributor out.  I put the engine at TDC #1, re-installed the distributor, then rotated the engine to make sure the distributor rotor was turning.  It was.  It doesn't seem to be 180* off either, since I'm not getting any spark at all.  I'm holding the spark-plug against the block while cranking the engine, no visible spark in the plug gap.  The plugs are new, and it ran a few days ago with the new plugs.
I am getting fuel, I pulled the plugs just a while ago and they had some gas on them.
Offline wyo-hunter
« Reply #3 on: March 07, 2009, 08:25:14 PM »
One other thing I forgot.  I washed the under-carriage the other day.  It ran rough for a while after that, but got me home.  Now it won't even fire.  ???
Offline norcalwreckchaser
  • 128
« Reply #4 on: March 08, 2009, 12:23:13 AM »
HHHMMM?? ??? This may sound crazy but, could it be your starter is stuck? I had a problem with a rebuilt starter not fully disengaging from the flywheel. Try rocking the vehicle in gear, I did so and was able to free up the starter gear from the flywheel, worth a shot.
BTW nice avatar, I too am a life member.
Norcal
Sold 7/10 :(
Offline wyo-hunter
« Reply #5 on: March 08, 2009, 02:04:20 PM »
success !! I replaced the fuse in the ignition circuit with an old one that was coroded enough that it didn't make contact. When I used a new one, it fired right up. One of those dumb things.
