Hey nice forum you all have here and lots of info. I have been searching for hours now and believe I have found my answers but I will throw this out at you all.
I have 6 throttle body 2 door model tracker/sidekick's. All in different stages of rusting out. So they are all roughly 90 91 92 models. 8 valve 1.6 right?
I just got a phone call today about a 95 2 door I was looking at with the motor gone. The body and chassis are clean, no rust. Well u know there might be some hiding but its a lot cleaner than any other one I have. I believe from what I have read that its a 1.6 16 valve because of the year, multiport fuel injection and different exhaust ports. Would this be right so far?
The owner is selling because a local garage has replaced the engine and the engine they put in destroyed itself in minutes and the owner killed the first engine beyond rebuildable. They have been searching for a couple months now locally and can't find a replacement motor.
So what I have learned is that the trannys are the same, and I gathered that it would bolt up from examining the bell housings and motor mounts. But I guess I have to change the whole wiring harness, computer and header so far. Do the fuel pump need to be changed? In one thread I read that they changed the dash aswell, do I need to do this or is it all plug and play?
Thxs in advance. I wanna build this rig to DD for awhile and eventully a fully capable offroad machine I can tow to the trail behind my 78 K5 Blazer.
Cyril
