MSD Ignition
  • 20 Replies
  • 10625 Views
Offline Dimitros
  • 75
Re: MSD Ignition
« Reply #15 on: March 04, 2009, 12:32:43 AM »
maybe there are coils, for each spark plug individually?
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
Re: MSD Ignition
« Reply #16 on: March 06, 2009, 09:22:11 AM »
My distributor is the same, the coil and ignitor assembly are built in. You would have to replace the dizzy with an earlier one with a seperate ignitor box.
The Sammy ECU is most likely remappable, I haven't seen inside one yet. It would probably need a daughterboard to allow it to be easily reprogrammed, similar to an early 16V Vit or Swift. There isn't a probem with the range on the MAP sensor. Unless its turbocharged, the maximum pressure will be atmospheric pressure.
Re: MSD Ignition
« Reply #17 on: March 06, 2009, 10:47:26 AM »
I think factory MAP still does okay with mild boost right  ???
Re: MSD Ignition
« Reply #18 on: March 07, 2009, 07:12:01 AM »
MAF works OK with mild boost, MAP is a 1 bar sensor (up to atmospheric) so it can't detect boost. Excessive pressure will trigger a CEL and cause the ECU to drop into limp mode.
« Last Edit: March 07, 2009, 07:13:47 AM by Rhinoman »
Offline Lunchbox5k
  • 46
Re: MSD Ignition
« Reply #19 on: March 07, 2009, 07:33:18 AM »
Thanks for all the info guys. Sounds like my best bet would be to toss a blaster coil at it and call it good. Its only 50 bucks who cares right. thanks again
91 Sidekick 8v
LSD in rear
Custom intake
Offline Dimitros
  • 75
Re: MSD Ignition
« Reply #20 on: March 08, 2009, 03:16:48 PM »
I got much more then just Blaster Coil under the hood, but still it sometimes work very poorly and next day it works just fine (next day is almost always dry and mild temperature weather). And again, when reving from 3500-3800 to 6800-7000 it hesitates. I gues that I need an ignition triggering system which wiil understand an EFI to CARB change on board and MSD 6 isn't one of it, it's just a ancillary system that improves overal combustion characteristics, not more.
So the simpliest way is to change distributor on a carb one, with vacuum advance, purely mechanical - ?
Remaping an ECU is quite a good choice if there's carb maps and equipment available to do this work.
Rhinoman, I'm driving on stock EFI dizzy on carb currently, and would love to remap my Sammi's ECU for proper carb timing, but it's practically impossible in my country. Easier and cheaper would to chip-up my A6 2.6 Avant from it's stock 150bhp to 178bhp (which is done) than my Sammi.
Anyway, when I'm done with my ignition problems I would deffinatly go to one of MSD boxes!
