Calmini VS OME
  • 24 Replies
  • 4765 Views
Offline 2K1USGV
  • 218
Calmini VS OME
« on: March 01, 2009, 05:34:29 PM »
So I'm about to get myself a new suspension but I can not decide between Calmini and OME. Do hte Calmini springs ride as rough as RR would have you believe? I'm looking for people with experience. The only problem I have with going OME is that I don't get the diff drop brackets, the rear track bar relocation bracket, and of course the A-arms. If I could get these things separately I would but the rest from OME, but since I can't I need your opinion......
Offline Sn0vv
  • 143
    • Cardomain Profile
Re: Calmini VS OME
« Reply #1 on: March 01, 2009, 08:08:39 PM »
All the Extra pieces that come with the calmini kit are recommended pieces in My Opinion
So IMO go with calmini
Please also keep in mind that when you raise your suspension(and possibly go offroad) your going to be putting more stress on the Stock body mount locations and hardware (frame+body combo)  and could possibly damage those areas...its always best to get a body lift kit as well which have some better spacers to avoid damaging those areas as the stock ones would do alot more over time........especially if the mount areas are rusty.
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline 2K1USGV
  • 218
Re: Calmini VS OME
« Reply #2 on: March 01, 2009, 08:27:08 PM »
You are incorrect about the body lift as this will actually move the body further from the frame, making the body to frame mount points weaker. It's like saying that my wheel hub to wheel connection will be stronger if I have wheel spacers installed. Simply not true and actually it's the other way around. That being said, I have a 2" body lift already installed.
Offline sir lance
  • 342
  • I love my XL-7
Re: Calmini VS OME
« Reply #3 on: March 01, 2009, 09:23:11 PM »
you have a lift already dont you?,for the price of calmini? little gains over yours in my eyes.
alot of people like the ride of the ome.....but i perfer to use stock springs and shocks so it rides like a stock truck. works well for me.
why do you want to change? more lift?
-Lance
Offline 2K1USGV
  • 218
Re: Calmini VS OME
« Reply #4 on: March 01, 2009, 10:19:57 PM »
Yeah, I guess it really comes down to just wanting more lift. I hear that the OME's are more comfy riding that the stock springs, that's what sparks my interest into them. My suspension lift consists of the RR 1" robber spacers and stock springs at the moment.
Offline IanL
  • 466
Re: Calmini VS OME
« Reply #5 on: March 02, 2009, 12:37:31 AM »
If you are at all interested in ride quality, OME is the way to go.  They are the only outfit who can provide lift AND an improved ride.
Calmini are often jokingly referred to as Calstiffy - every description I have read of their ride explains that one.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline olija
  • 770
    • Check out my cardomain
Re: Calmini VS OME
« Reply #7 on: March 02, 2009, 07:21:40 PM »
I chose the Calmini over the OME because
a) the a-arms
b) the ball joints are bolted on like the Sidekicks, much easier to replace
c) I think the stock suspension is too soft with a box of tools and a bunch of other crap in the back. I was always bottoming out the rear of my Sidekick, ESPECIALLY with rear passengers!
d) I wanted as much lift as possible to clear 31's and have lots of room for flexing. Calmini makes the biggest lift.
e) I figured if the ride REALLY sucks I can always upgrade the struts to FTS or OME and do something about the rear too if necessary.
Offline dentedzuk
  • 171
Re: Calmini VS OME
« Reply #8 on: March 02, 2009, 07:46:22 PM »
If I had to do it over I would just stay with spring spacers.. especially now that jeff has diff drops! ..Way cheaper -factory softness! I have the calmini kit and its alright.. but an extra 2.5" of spring  isn't gonna make a vittrack an off road monster.. need a sas for that..
2001 2.0L 4dr Vit: Calmini 2.5" susp, 215/65R16's, Surco safari rack, cone filter, turbo muffler!
***FOR SALE***
2" R.R.O. B/L w/ steer extension - $125
Trackkick axle, $50
stock Vit springs - $50
2x 225/75R16s A/Ts(95% tread) -$85
pics- http://www.zukiworld.com/forum/index.php?topic=24765
Offline 2K1USGV
  • 218
Re: Calmini VS OME
« Reply #9 on: March 02, 2009, 10:21:29 PM »
Who's jeff and where can I get his diff drops?
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Calmini VS OME
« Reply #10 on: March 02, 2009, 10:52:10 PM »
For me, I'm an OME convert.   The Calmini arms would be great but I don't want to spend the bucks for the entire kit when all I would really want out of it is the arms and diff drops.
Running down smooth hardball roads stock spring and coil spacer combos are fine.  The truck handles fine at highway speeds and when turning.  I've had a set of Jeff's coil spacers on one of my trucks for almost two years now and I don't have any complaints on their durability or performance... or price for that matter.  They are solid, they get the job done and they are still the best inexpensive way to gain lift on your truck.  However I've noticed my passengers get launched up out of their seat into their seat belts pretty hard when the rear end kicks over a bump on trails.  Especially when the belt locks up as they are rising in the seat.
I can appreciate guys who need heavier spring set-ups to hold all their gear on the go, though.
« Last Edit: March 03, 2009, 03:16:41 PM by nprecon »
Re: Calmini VS OME
« Reply #11 on: March 03, 2009, 06:13:17 AM »
I didn't know Jeff had diff drop brackets.
Offline bzzr2
  • 1011
Re: Calmini VS OME
« Reply #12 on: March 03, 2009, 06:53:59 AM »
i put xl7 rear coils to eliminate the soft stock spring problem, with mustang shocks they can ride rough with no weight but add a few pounds in back and the ride is good.  anyway, it's an option for people wanting something stiffer in the back to carry shit
09 taco reg cab short box 4x4
Offline dentedzuk
  • 171
ert
« Reply #13 on: March 03, 2009, 11:04:58 AM »
If i keep my vit,  I might try jeep coils in the rear since i can get some from a buddy for free.  Last summer i wasn't impressed with the way the back of my zook saged loaded up for camping.
**my bad strut spacers not dif drops!!!!
***FOR SALE***
Trackkick axle, $50
Offline 2K1USGV
  • 218
Re: Calmini VS OME
« Reply #14 on: March 03, 2009, 02:49:46 PM »
I'll have all 4  XL-7 coils available soon if anyone is interested :)
