New Toy SAS kick from Québec!
  • 26 Replies
  • 4408 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: New Toy SAS kick from Québec!
« Reply #15 on: August 25, 2004, 01:34:31 PM »
Wow, not bad. Have a look at mine. I have installed a D44 front and Ford9" from a 66' Bronco with Spools and 5.83 gears. I also run 35" MudRover tires from Dunlop and a Twin stick convert to go 2WD low.
What do you think ??? ;D
 NO PIC. HERE  ???
Offline Natebert
  • 1098
« Reply #16 on: August 25, 2004, 06:20:37 PM »
here found this at another fourm, thought it might help.
Axle info - Toyota
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
stu
So FJ80's look like the choice to widen up the trackwidth AND to gain extra beefiness, without total custom fab stuff.  (thanks for the WMS info)  I never dug into it until now.
That'd give ya bout 3 inches of extra width on each side.  (no more need for offset rims)  Keep the tires off of the frame and shocks.  Provide better stability, no need to inboard the shocks, etc, etc, etc..
THANKS!
« Last Edit: August 25, 2004, 06:22:11 PM by natebert »
Offline CanadianZook
  • Always towin the Toyotas !!
« Reply #17 on: August 26, 2004, 02:12:04 PM »
 :-[     Sorry about the no picture happening.
Heres a link to my site. (just started with this web stuff)
http://www.d1kh3d.com/6928.html
I'm new to this forum and I havent found a way to post a pic.
Any one know how without flaming me??
Thanx,
« Last Edit: August 26, 2004, 02:13:08 PM by CanadianZook »
92' Kicker, D44F, Ford9",Spools,5.83 gears, MMarker Winch, 35" MudRovers
Offline 1bigtracker
  • 3409
« Reply #18 on: August 26, 2004, 03:01:35 PM »
Thanx,
i don't know how to post pics but don't worry about flaming, we are VARY strict about rude comments.  welcome abord!
stu
  • 2274
« Reply #19 on: August 27, 2004, 02:54:45 AM »
CanadianZook
« Last Edit: August 27, 2004, 02:57:12 AM by NY_SIDEKICKER »
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
« Reply #20 on: August 27, 2004, 12:19:19 PM »
He attached the upper link to the radius arm.  Is this ok?
The angle of the diff won't move like a true 3 link suspension, such as on the rear of a Kick.
Offline 1bigtracker
  • 3409
« Reply #21 on: August 27, 2004, 01:00:26 PM »
humm i don't see how any of that works??? at first i was thinking that it was kinda like the older fords radius ares but it don't look like it???
stu
Offline explosivo
  • 3157
« Reply #22 on: August 27, 2004, 03:15:44 PM »
It reminds me of how the RRO setup is up front... there's just the two links (it looked like) with 2 bushings on the end of each link. Or at least that's what some of nc_zuk's pics made it look like :)
omghi2.us[/url]
Offline snakeman
  • 274
  • Alrighty Then
    • Oregon Trail 4x4 Association
« Reply #23 on: August 28, 2004, 07:49:07 AM »
I see how part of it works. 2 main links from frame to axle, 1 link each side from main link to top of axle.
He'd still need a trac bar, and the upper links look kinda weak where they attach to the lower links, maybe unfinished and yet to be braced in the pic.
Rig looks sweet though! I love SA Kicks
My .02
Oregon Trail 4x4 Association - Eugene, Oregon
http://www.ot4x4.org/[/url] Come check us out if your in the Eugene / Springfield area!
87 Tin Top, 1.6 16v, 4.9, 4.62's w/ sidekick rear, TT YJ swap, custom snorkle.
Offline snakeman
  • 274
  • Alrighty Then
« Reply #24 on: August 28, 2004, 07:53:01 AM »
He attached the upper link to the radius arm.  Is this ok?  ...
(Just reread the post)
What size tubing are you using for the radius arm? I have heard of the links breaking or tearing off under load. Brace it good.
Offline 1bigtracker
  • 3409
« Reply #25 on: August 28, 2004, 08:30:31 AM »
i agree,  i'm am now starting to see how it works and it should flex well!
ctu
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #26 on: August 28, 2004, 12:33:46 PM »
You need to find someone, or some place that you can host pics from... For example, say cardomain.com. It sucks, but it works.. Upload the pics to car domain, then view your pic, right click, select properties, then copy the link to the pic.
Then, go to where you want to make your post with the pic and paste the link and add in the IMG tags.. Or, drag over and highlight the link, and click the button above...
IMG tags should be "[ img]" at the beginning of the link, with "[/img]" at the end of the link. No spaces between the tags and the link on either side...  ;)
« Last Edit: August 28, 2004, 12:35:01 PM by r0ckstarr79 »
