Agreed. Might better consider going stock OEM shocks and struts if you don't intend to lift the body thru the suspension. You'll pay about twice as much for the OME struts as stock Gabriel or Monroe struts. If you intend to lift your truck in the near future then go with a set of Jeff's coil spacers for an inexpensive suspension lift and then the OME struts and longer shocks idea would serve a functional purpose. Later on you might consider adding a set of OME coils and have a very nice riding trucklet. Nothing says you have to go with larger tires just because you lift your truck. You gain more ground clearance with spacers or new coils anyway and these trucks look better sitting a little higher.
My suspension is worn at 155k miles, and the last cupl thousand on the BFG's were not nice to them. As i am getting new KO's (after 45,000 miles) and wife is not that enthused about the lift as yet (it is our DD) I have decided to go stock struts from KYB amd the KYB gas a just for the rear. Have any of you had to replace other front end parts at this point? Ball joints, tie rod ends, etc? I also will get a thrust alignment to check the rear axle plumb.
A reminder, the toe in nec to avoid uneven inside edge wear gets bigger as things wear. At "0" toe, the forward thrust gives a kinetic toe out that hurts the tires.
Oh, yeah, what is the effect on camber with major junk in the truck, plus cargo platform? Will I ruin tire wear if I run heavy too much? I have learned that the camber is altered when the weight on the front is lessened. How much this affects my GV, I do not know.
Thanks for the insight. This is a great site.
Pat
