I DID IT!!!!
  • 1550 Views
Offline bandit86
  • 1641
  • elv8rguy
I DID IT!!!!
« on: August 29, 2004, 12:18:38 PM »
I thought it would never happen.  snapped my front differential housing.  I've been waiting for this for a long time.  all it took was 33s stuck in clay, back in the air, and a tiny wheelhop.
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
Re: I DID IT!!!!
« Reply #1 on: August 29, 2004, 12:19:46 PM »
Sweet! Got pics? What are ya gonna replace it with? Same thing or better? I just broke a Ujoint myself.
Re: I DID IT!!!!
« Reply #2 on: August 29, 2004, 01:38:32 PM »
You sound so happy.
At lest it lasted longer than my first stocker.
Well at lest you KNEW it was going to happen, just not when.
Offline 1bigtracker
  • 3409
Re: I DID IT!!!!
« Reply #3 on: August 29, 2004, 01:39:11 PM »
congrats!  i posted my first front end brakeage too but it starting to get old quick.  the second one isn't as fun. nor is the third...
stu
Re: I DID IT!!!!
« Reply #4 on: August 29, 2004, 01:53:59 PM »
When something breaks it means its a weak link.
Go find a GV frontaxle and a Sammie rear center section.
(HAWKS) ;)
I know it aint cheap, but its cheaper than replacing the same part 3times. ;)
That happened to my friend (3times) so I learned from him the right way after I broke mine.
When you break you front end, The stock centersection as 2 spider gears where the Sammie has 4.  The stock spider gearshaft gets bent (you can't see it) and every time you reuse that one it'll chew up your gears and break again.
(From what my friend told me or he just wanted to sell me his Sammie center ;))
Offline explosivo
  • 3157
Re: I DID IT!!!!
« Reply #5 on: August 29, 2004, 03:02:52 PM »
(HAWKS) ;)
Don't you need a rear Sammy 3rd in front to run an ARB locker anyway?:P
omghi2.us[/url]
Re: I DID IT!!!!
« Reply #6 on: August 29, 2004, 03:30:01 PM »
Hey, that also means you can use
a sammy rear ARB up front in a Track/Kick
Hmmmmm.......
