rough idling and other problem after overhaul
  • 902 Views
« on: February 16, 2009, 04:39:34 AM »
Hi guys!
I just had my Grand Vitara 2.5L V6 overhauled. It only ran 130,000+ kms on the odo when I had it overhauled. My reasons were primarily of the leaking crankshaft seal and strange engine noise. As it turned out the problems were dried and cracked crankshaft oil seal and worn out timing chains and guides. I had it all replaced with genuine suzuki parts, no problem there. It also turned out I already had some poor combustion due to leaks in some valves, so I had the valve seats cut, so I also replaced the cylinder head gaskets and valve seals. My mechanic had my valve lash adjusters "reconditioned" by first leaving them soaked in gasoline and then finally cleaned in lacquer thinner. He purged the insides of the adjusters by repeatedly depressing and releasing the center part (the one that actually contacts the valve stem). I too had taken part in the activity and noticed that not all adjusters needs the same equal amount of pressure to depress to its extent.
To make my story short, we had it running already. The problem now is that it idles roughly, well i dont know if its the right term. As I feel it, the car seems to vibrate when its idling. Also I noticed while running it lacks power and like pressing a nitrous button it suddenly jolts forward with awesome power. My mechanic says that maybe a valve or some of it is not seatin well or the adjusters could be stucked  making the valve not seat so well or the adjusters could be stuck and not bleed right making the valve not seat so well thus the erratic and sudden power surge.
What do you think guys?
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: rough idling and other problem after overhaul
« Reply #1 on: February 16, 2009, 04:45:18 PM »
A part of the problem may be the lifters.  They may not have recovered their oil volume.  On the Chevy Tracker 2.5L engine the manual makes a point to stress not to apply force to the body (valve side of the lifter) because it forces oil out of the lifter.  The manual states to store the lifters submerged in clean engine oil with the camshaft side down until installation to prevent oil from draining from the lifter/s.
« Last Edit: February 16, 2009, 04:46:49 PM by nprecon »
