Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
Spare Tire Lift Bracket
Emmission
11
February 10, 2009, 06:45:12 PM »
If you have a 1999 - 2004 GV or Tracker, have you been able to mount a 31" tire on the spare tire carrier, or does it rub against the bumper. I saw this guys product on ebay that seems to cure the problem. The question is, is it a problem?
2K1USGV
218
I Love ZUKIWORLD!
Re: Spare Tire Lift Bracket
February 10, 2009, 08:40:25 PM »
Is it absolutely necessary? No. Will your 31" rub the bumper without it? Yes. It will push the plastic bumper cover down a bit. Also depends if it's a true 31" tire or a 30.5" tire.
JayInBarrie
107
February 11, 2009, 06:22:28 PM »
Take the plastic off the rear bumper. The metal looks ok, just paint it black.
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
sir lance
342
4
I love my XL-7
Reply #3 on:
February 11, 2009, 08:31:30 PM »
the 245 mtr's i ran on my GV JUST fit over the bumper, again it depends on what the tire actually measurs out to
Yankee-Tim
562
Reply #4 on:
February 12, 2009, 10:29:17 AM »
On my 31"s, I just drilled new upper holes and used a carbide rotaty bit to hog out the lower mount holes, and lifted the mount and bolted it back down. Even carrying the tire AND a full Gerry can, it never moved.
Cost? Free
jeff1997
1228
27
Suzuki: A Jeep thing only cheaper!!!!
Reply #5 on:
February 12, 2009, 10:41:10 AM »
I cut the mount down the middle and welded it together offset. It was nessesary to clear my 31's
2" coil spacers- I make and sell 1.5" and 2" on e-bay. Look under seller: hoepkers
3" Masterkit1 body lift
Custom strut spacers
bzzr2
1011
3
Reply #6 on:
February 12, 2009, 11:28:25 AM »
drop the bumper covers.. if you're wheeling for real (not just driving down dirt roads..) the plastic will eventually just get torn off anway. i've even torn the whole steel bumper off hooking it on a massive hidden stump in a swamp.. more gas was bad that day!
09 taco reg cab short box 4x4
sir lance
342
4
I love my XL-7
Reply #7 on:
February 12, 2009, 11:30:27 AM »
^^^ i did that once as well on my sidekick, only i hooked it on a tree and tore it clean off hahahaha
toofaroffroad
226
2
I Love ZUKIWORLD!
Reply #8 on:
February 13, 2009, 09:13:30 PM »
I run a 31 inch spare and it's fits fine. I put a 1/4 wheel spacer to push it back a bit but honestly I don't think that is necessary. That is on the stock spare rim.
99 tracker
Last Edit: February 14, 2009, 09:23:56 AM by toofaroffroad
