Sammy only start if I put gas in carb.
  • 1814 Views
« on: February 07, 2009, 07:29:43 AM »
Hi.
My 1988 Samurai only start if I put a little gas by the carb.
Once it start ,stay in idle and run normal.
What could it be ?
Sorry for my english.
Re: Sammy only start if I put gas in carb.
« Reply #1 on: February 07, 2009, 11:19:58 AM »
Sounds like your choke isn't working.
« Reply #2 on: February 07, 2009, 11:20:29 AM »
Have you tried pumping the gas twice before starting  ???
« Reply #3 on: February 07, 2009, 12:04:58 PM »
I think that the  previous owner remove it .
I dont see the choke knob.
But even if the engine is warn has the same problem.
« Reply #4 on: February 07, 2009, 12:05:40 PM »
Yes.
« Reply #5 on: February 07, 2009, 03:04:53 PM »
Might be a partially plugged carb.  Not getting enough gas to fire off, but once it is running it works fine?
If it's a Samurai it should have an electric choke.  Someone else will have to verify that though.
« Reply #6 on: February 08, 2009, 02:30:46 PM »
Now the car start when I put gas through the carb but don't stay in idle.
« Reply #7 on: February 08, 2009, 03:24:14 PM »
I think you need your carb tuned or cleaned up. Have you done alot of mudding? Because 1 little peice of dirt in a jet can cause worlds of problems.
« Reply #8 on: February 09, 2009, 12:17:03 AM »
It's either fuel pump, fuel filter, or carb. I don't know how to test your fuel filter, but you should be able to pull the fuel line, and see if fuel is pumping out when the engine's being turned over (don't be an idiot with this and catch yourself on fire). If not, then it's a bad pump or filter for sure. Here's a couple carb cleaning guides:
http://bbs.zuwharrie.com/content/topic,31520.0.html
http://www.zuwharrie.com/component/option,com_smf/Itemid,40/topic,21551
You can also try replacing the carb with a cheap junk yard. Go here and search for "carb":
http://www.acksfaq.com/
