Can a/c blower from 97 tracker fit 92 tracker?
  • 9 Replies
  • 2775 Views
« on: February 04, 2009, 07:16:02 PM »
Can the blower motor (for the a/c) from a 97 Geo tracker fit in a 92 geo tracker? Found one at a garage today, I only had enough time to pick up the center console with cup holders for 5 bucks in new condition!  8) but I also need a blower as mine blew out but the tracker is a 97 softtop and mine is a 92 tintop. is there any difference in the blowers? thanks!
« Last Edit: February 05, 2009, 09:22:53 AM by bartolo92 »
J1 TINTOP FOR 500 BUCKS AINT BAD AT ALL!
Re: Really Quick question I hope to get asnwered ASAP!
« Reply #1 on: February 04, 2009, 07:18:50 PM »
oh yeah, 1 more thing, there is also a sami in this yard and the manual hubs look to be in excellent condition! can these manual hubs work on my 92 geo tracker with no mods?
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: February 04, 2009, 09:43:35 PM »
Before you change the blower check the resistors stuck in the heater box behind your glove box, they are known to burn out.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #3 on: February 04, 2009, 11:35:41 PM »
really? We pulled out the blower and hooked it up to a car battery and it didnt run, doesnt this mean is does not work? I can double check tomorrow, but do you know if the blowers are the same for 92 and 97?
« Reply #4 on: February 05, 2009, 08:43:43 AM »
Any know if the blower and the 97 geo tracker is the same in a 92 geo tracker? I need to know ASAP!  ??? Thanks!
Also, the manual locking hubs on a sami, can they be used on a 92 geo tracker with no mods? I have 4wd with manual locking hubs already but on the sami, they seem to be in way better condition! Please, someone help me! thanks!  :o
« Reply #5 on: February 05, 2009, 08:52:34 AM »
Not sure on the blower.  I would think so, as most of the interior pieces are the same between years.  Hooking it up to 12v should work, but test both of your blowers.  If one works and the other doesn't...
You can use the front hubs, but you will need to space them out just a pinch.  Apparently just using two gaskets gives you enough space.
Offline Vagabond
  • 95
« Reply #6 on: February 05, 2009, 09:10:35 AM »
You'll get more answers to your questions if you compose a descriptive subject line.
[/url]
Re: Can a/c blower from 97 tracker fit 92 tracker?
« Reply #7 on: February 05, 2009, 09:23:17 AM »
thanks lol, i changed it now, hopefully it would work
« Reply #8 on: February 05, 2009, 06:30:45 PM »
here is an update, I picked up the blower, it worked when hooked up to a battery, picked it up for 22bucks, its looks spankin brandnew! hooked it up and it worked! you can see below of the tracker which is in my area. sucks though, the sami i was looking to take the mani locking hubs just happaned  to be crushed this morning!  :'(
« Reply #9 on: February 06, 2009, 01:29:48 AM »
Shame you lost out on the hubs.  Even bigger shame the Sammy was crushed...
