Sidekick drive line flange does this mate to the toyota axle flange?
bashzuk
784
Been zuked lately!!!
January 30, 2009, 10:27:32 PM »
I've been told that this mates right up. Is this true?
Mean Green Wheeling Machine
bashzuk
784
Re: Sidekick drive line flange does this mate to the toyota axle flange?
February 06, 2009, 08:28:00 PM »
No one knows if this is true
Drone637
8121
116
Evil Cow
February 06, 2009, 10:36:37 PM »
Supposedly. I have also read that you need to modify the drive line as well, getting rid of the lip, so the only thing holding it in place is the bolts. Low Range Off-Road has adaptors for 25 dollars a piece at
http://www.lowrangeoffroad.com/samyotaswap.htm
and is probably the easiest. Did you find a set of Toy axles?
Another article I found mentioned that the transfercase side flange of the post 85 Toyota front drive shafts will bolt up to the large flange Tracker transfer cases. Haven't seen confirmation on that though.
bashzuk
784
Reply #3 on:
February 09, 2009, 03:55:31 PM »
Yeah I have a set laying around and I'm trying to figure out if I'm going to use them or not.
biker
730
7
It's a sickness I tell ya
Reply #4 on:
February 09, 2009, 09:01:26 PM »
If you mean Sidekick driveshaft to Toy axle then the answer is not really. It will fit into the aligning hole in the center but only 2 bolts will line up, this is on an early Toy axle and I think the later ones have a bigger bolt pattern.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
