Project Kickota
  • 133 Replies
  • 33555 Views
0 Members and 15 Guests are viewing this topic.
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Project Kickota
« Reply #45 on: March 02, 2009, 09:22:46 PM »
You couldn't afford me  ;)
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline Lindenmooch
  • 560
Re: Project Kickota
« Reply #46 on: March 02, 2009, 09:38:03 PM »
Offline 91zukisas
  • 140
Re: Project Kickota
« Reply #47 on: March 04, 2009, 07:43:41 PM »
28" of travel, NICE
91 2door Sidekick yota Axels  SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project :D
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
Offline biker
  • 730
Re: Project Kickota
« Reply #48 on: April 04, 2009, 06:12:49 PM »
Haven't been working on it much lately but I got the brakes all working and adapted the Toy park brake to the Kick lever and it seems to work well.
I picked up a twin stick setup for my Toy case and my new tires showed up too >:D Had to test fit the new boots and see where to trim.
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #49 on: April 04, 2009, 06:18:25 PM »
Couple more, The yellow truck is being retired when the blue one is ready and I'll be doing some transplants between trucks. The red one is my brothers rig
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #50 on: April 04, 2009, 06:25:32 PM »
I've changed from my original motor swap plan due to incompleteness of the donor truck so I'm pulling the motor and rebuilding it with some performance upgrades and swapping in my trusty old 3spd auto with 4.24 gears in the Kick case and stock 2.28 in the Toy case. I'll update when I get some work done on the motor.
« Last Edit: April 06, 2009, 07:04:48 AM by biker »
99 Vitara 2wd
10 Gr Vitara
Offline allout
  • 41
Re: Project Kickota
« Reply #51 on: April 08, 2009, 10:16:17 PM »
Hey Duane, its Jeff. Wow this is lookin great. I am going to have to come out and see it in person. Keep up the great work.
94 Tracker, SAS with YJ's, spartan locker front , welded rear, 33/10.50's, 4.24tcase gears, Warn M8000. Toy axles being built up.
Offline biker
  • 730
Re: Project Kickota
« Reply #52 on: June 21, 2009, 08:47:44 PM »
Well it's been a long time since I updated this thread. Not much happened for quite awhile due to waiting for parts and life stuff keeping me out of the garage. I have managed to make some headway again and now I have set myself a deadline so time to get busy.
I decided to fully retire my yellow truck after exploding the R&P then rolling it(it was a rough day lol). I pulled the tranny for my new truck and hooked the Kicker2 to it.
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #53 on: June 21, 2009, 08:52:58 PM »
The motor was completely rebuilt and a performance grind was done to the camshaft by Colt Cams.  I tossed it all together and gave it a shot of paint from my leftover paint collection.
Then it was all bolted together and set back in the truck.
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #54 on: June 21, 2009, 09:13:39 PM »
Next was the t-case crossmember, I picked up a new Trailgear dual Toyota case crossmember for $60 and relief cut it and flattened it out to work for my application. I quickly made up a couple angle brackets and welded them to the frame for something to bolt the x-member to. Then bolted everything up. Almost a flat belly but I think with a little more massaging of the floor I can get it flat, so I may have to revamp the x-member a little yet. Looks like the twin stick on the Toy case will come through the floor in the forward end of the stock t-case shifter hole and the Kicker2 shifter will come up beside the stock shifter.
« Last Edit: June 21, 2009, 09:17:12 PM by biker »
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #55 on: June 21, 2009, 09:22:09 PM »
I also got my modified Birfs back from a local guy that beefs them up so I put my front axle completely together. Just waiting for my GM alt bracket from Low Range and a new rad then the front clip can go back together. After that I will start on bumpers and cage.
99 Vitara 2wd
10 Gr Vitara
Re: Project Kickota
« Reply #56 on: June 24, 2009, 01:26:57 PM »
Looks good.   Are you going to add some additional bracing to your angle iron mounts?
Offline biker
  • 730
Re: Project Kickota
« Reply #57 on: June 24, 2009, 05:25:44 PM »
I don't think I'll need to as the forces against the x-member are upward and it is against the bottom of the frame rails
99 Vitara 2wd
10 Gr Vitara
Offline v-stone
  • 625
Re: Project Kickota
« Reply #58 on: June 24, 2009, 10:06:47 PM »
Looks good. I like the wishbone links for the front, strong and simple. How is the shorter pan hard bar working out?
SAS Tracker! No looking back now.
Offline biker
  • 730
Re: Project Kickota
« Reply #59 on: June 25, 2009, 06:41:43 AM »
I think the panhard will be ok but I won't know for sure until I actually get to wheel it
99 Vitara 2wd
10 Gr Vitara
