Project Kickota
  • 133 Replies
  • 33532 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Project Kickota
« Reply #15 on: February 02, 2009, 04:22:37 PM »
Thanks :) I just hope it works good after I'm all done
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline 91zukisas
  • 140
Re: Project Kickota
« Reply #16 on: February 09, 2009, 06:18:28 PM »
Looking good
Cant wait to see it done
91 2door Sidekick yota Axels  SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project :D
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
Offline RHodge
  • 523
Re: Project Kickota
« Reply #17 on: February 09, 2009, 08:51:22 PM »
Yes, looks good  :)
Offline biker
  • 730
Re: Project Kickota
« Reply #18 on: February 10, 2009, 06:41:54 AM »
Thanks guys. I almost got the rear finished now so when I do I'll update with a couple pics. Next step is to pull the motor,trans and case and replace.
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #19 on: February 15, 2009, 07:38:37 PM »
Well I got the back springs put in this weekend and hooked up the brakes, still waiting on E-brake cables. I decided to try out some TJ coils for now and see how they flex.
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #20 on: February 15, 2009, 07:40:46 PM »
A couple more, just because 8)
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
Re: Project Kickota
« Reply #21 on: February 15, 2009, 07:42:48 PM »
Next step is to pull the motor and trans out along with the wire harness and replace it with a 1.8, 4spd auto, Kicker2 with 4.24:1 gears in the front case. >:D
99 Vitara 2wd
10 Gr Vitara
Offline Lindenmooch
  • 560
Re: Project Kickota
« Reply #22 on: February 15, 2009, 07:55:31 PM »
SUHWEEEEET!!!!    ;D
Nice job!   I wish mine was that high!!
Offline 91zukisas
  • 140
Re: Project Kickota
« Reply #23 on: February 15, 2009, 08:43:48 PM »
NICE WORK 8)
Offline 91zukisas
  • 140
Re: Project Kickota
« Reply #24 on: February 15, 2009, 08:47:49 PM »
the 36" tires look perfect
Offline zukizuki07
  • 251
Re: Project Kickota
« Reply #25 on: February 15, 2009, 10:00:54 PM »
have you measured your fender-ground?? i keep going crazy looking at those  pics and trying to figure out if the rear is lower than the front. ???
96 2 Door Tracker
Offline RACER X
  • 383
  • zuki or die!
Re: Project Kickota
« Reply #26 on: February 15, 2009, 10:42:34 PM »
front just needs a winch
98 kick
Offline biker
  • 730
Re: Project Kickota
« Reply #27 on: February 16, 2009, 06:36:51 AM »
The tires on it are 315/16's and are supposed to be 35's but only measure just over 33", the Irok's will be a little bigger.The front is a little higher than the rear but I have to install my bumper with winch and a cage yet so I'll see how it sits after that and adjust as needed. Thanks for the comments  :)
« Last Edit: February 16, 2009, 06:40:06 AM by biker »
99 Vitara 2wd
10 Gr Vitara
Re: Project Kickota
« Reply #28 on: February 17, 2009, 07:25:35 PM »
Great job on the 4 door... Looking good  8)
Offline biker
  • 730
Re: Project Kickota
« Reply #29 on: February 17, 2009, 08:03:03 PM »
Thanks Zig, I've been drooling over your new toy myself
99 Vitara 2wd
10 Gr Vitara
