Project Kickota
  • 133 Replies
  • 33523 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Project Kickota
« Reply #120 on: June 29, 2012, 06:50:42 PM »
The A pillar mount is from a Honda CRX and I had to trim it a little to fit but pretty easy. I think it run me about $700 for everything.
Yours is a lot nicer looking install Mike. I had to remove the ac comp that I was using for onboard air but I might try to find a big enough shoehorn to fit it back in as I really miss having air on the trail. It seems to work pretty well but I think it's addicted to meth as it likes to drink it on the highway. Might help if I wasn't doing 120km/h though >:D
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
Re: Project Kickota
« Reply #121 on: July 16, 2012, 05:17:05 PM »
did you move the front spring perches?
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
Offline biker
  • 730
Re: Project Kickota
« Reply #122 on: July 17, 2012, 06:45:49 AM »
Yes, factory mounts were cut off and new ones made to line up with axle placement.
99 Vitara 2wd
10 Gr Vitara
  • 162
Re: Project Kickota
« Reply #123 on: July 17, 2012, 08:32:23 AM »
okay thanks. im doing toyota axles on mine to its a 98 4 door. im using jeep rubicon express long arms for my front and i dont know yet for the rear but i think im going to build my own links and 4 link it. oh did you move the rear spring and shock mount to and how long were your front links?
-chad
« Last Edit: July 17, 2012, 08:37:33 AM by chadstichter »
Offline biker
  • 730
Re: Project Kickota
« Reply #124 on: July 18, 2012, 06:22:46 AM »
Rear upper mounts are in factory position but that may still change. I can't remember front arm length off the top of my head but I think they are around 30"  They end even with my front transfer case output
99 Vitara 2wd
10 Gr Vitara
  • 162
Re: Project Kickota
« Reply #125 on: July 18, 2012, 01:19:39 PM »
okay thanks this should help me a lot
  • 162
Re: Project Kickota
« Reply #126 on: July 23, 2012, 05:03:50 PM »
how do you do twin stick can you just hook to stock ones togerther? i have another stock one from a parts car and if could do that i would.
thanks, chad
Offline biker
  • 730
Re: Project Kickota
« Reply #127 on: July 24, 2012, 06:41:24 AM »
The twin stick is on the toyota t-case and it does involve a little work inside the case to install
99 Vitara 2wd
10 Gr Vitara
  • 162
Re: Project Kickota
« Reply #128 on: July 24, 2012, 07:41:11 AM »
okay what is the difference betwean twin stick and dual casses?
Re: Project Kickota
« Reply #129 on: July 24, 2012, 12:19:53 PM »
Twin Sticks is a setup that allows you to engage low range and 4wd independently.  On some t-cases it allows you to disconnect the rear drive line and run in front wheel drive.  The advantage of this setup is if you just want to go slow but don't need 4wd you can.  It can also help with maneuvering your vehicle if you have a front locker on tight trails since the front end will not lock up and cause the vehicle to push through corners.
Dual t-cases gives you two low range options, but the rear t-case you still have to be in 4wd to be in low range.  This has the advantage of allowing your gear ratios to stack up.  You can have two 2:1 t-cases and have 2:1 or 4:1.  Or you can have a 2:1 and 4:1 t-cases and have three gearing options of 2:1, 4:1 or both engaged for 8:1.
You can also get real fancy and run both a dual t-case and dual sticks.  :)
  • 162
Re: Project Kickota
« Reply #130 on: July 24, 2012, 12:54:31 PM »
okay thanks thats really helpfull. can you do dual casses to a stock sidekick case. or do they make a kit or something that will work for one
Re: Project Kickota
« Reply #131 on: July 24, 2012, 02:57:14 PM »
The closest I have seen is the kicker series that allows you to mount it to a Samurai t-case or to a Toyota T-case.
You should probably spawn a new thread to discuss options there.
Offline biker
  • 730
Re: Project Kickota
« Reply #132 on: July 25, 2012, 06:48:55 AM »
Thanks for filling in the info Drone, couldn't have said it any better
99 Vitara 2wd
10 Gr Vitara
  • 162
Re: Project Kickota
« Reply #133 on: July 25, 2012, 10:43:14 AM »
okay thanks. and sorry for drillin you guys with questions
