Front Diff Question!
  • 1231 Views
Offline Armour
  • 360
« on: January 29, 2009, 06:54:13 PM »
I am looking to do the XL-7 front diff upgrade to my tracker. I was wondering what year XL-7 housing I need to get! And if for a manual or Auto! Any info and assistance would be greatly appreciated!
Offline zukizuki07
  • 251
Re: Front Diff Question!
« Reply #1 on: January 29, 2009, 08:29:19 PM »
99+ (i think)
if you are looking to swap out the gears too you will want a manual setup to keep your gearing (assuming you have a 5 speed)
96 2 Door Tracker
Offline idaholwb
  • 772
« Reply #2 on: January 29, 2009, 11:46:44 PM »
You need a front housing from an XL-7 and the front drop-out from a GV, both with manual transmissions. The gear ratio is irrelevent because yours is different and you need to regear the new front diff with your gears.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Armour
  • 360
« Reply #3 on: January 30, 2009, 04:13:38 PM »
I can run my current gears can't I?
Offline zukizuki07
  • 251
« Reply #4 on: January 30, 2009, 05:16:57 PM »
yes, the GV drop out is just steel
96 2 Door Tracker
