Toyota axles and driveshafts
  • 966 Views
Offline Dazookster
  • 61
« on: January 20, 2009, 07:15:16 AM »
So I am going to put some toyota axles under my Samurai and I have heard that you should get an offset rear diff is that true?  Won't a cv driveshaft work my zook doesn't break 60 mph that often anyways.  What are the problems if I don't do a CV shaft?
Wahoo for Global Warming more time to go Wheeling
Re: Toyota axles and driveshafts
« Reply #1 on: January 20, 2009, 11:23:13 AM »
I think it is called a double compound angle and you will get a vibe at about 25 mph, so you have to go faster or slower than that, the transfer case also has more twisting on it so to speak so the driveline angle is trying to rip it out of the mounts more is the only way that I know how to put it, I drive a friend of mines Heep that has the same thing going on with a narrow Dana 44 and it loosens up the rear yoke once and a while and is hard on u joints other than that I have put allot of miles on it with a vortec doing 80 mph so there ya go  and also his drive shaft is under 12" in length.
