New Carb
  • 1281 Views
Offline Justzukin
New Carb
« on: January 07, 2009, 05:08:25 AM »
I am have trouble with my stock carb and thinking about going to a weber. Does anyone know of a good dealer and part number.  Has any one tried a Holley 350 CFM?
Thanks
Justzukin
1988 Sami 8" SPOA from Rocky Road 33/12.5 Tryus 6.5 to 1 super crawler ARB's both ends
Offline Amilla
  • 1076
Re: New Carb
« Reply #1 on: January 07, 2009, 09:43:35 AM »
Ever think about going side draft?
http://lowrangeoffroad.com/samengine.htm
http://www.petroworks.com/drivetrain-carberators.php
Scroll the way to the bottom for there side draft kit....they also sell Weber's.
Amilla
Offline Hillbillydave
  • 213
Re: New Carb
« Reply #2 on: January 07, 2009, 08:34:43 PM »
Holley would/could be an option...I went old school, 1971 Rochester 2-barrel
Re: New Carb
« Reply #3 on: January 08, 2009, 03:04:49 PM »
Just get a junk-yard carb & rebuild it. It'll be way cheaper, and flow the same. A lot of JY carbs don't have the float-bowl issues nearly as bad as the Webber.
Then - you could look into doing propane. Which will leave you open to a cheap turbo upgrade in the future...
Offline rascott
  • 669
  • 15
Re: New Carb
« Reply #4 on: January 08, 2009, 10:35:42 PM »
a rebuild kit is cheap and not too difficult.
it kept my stocker working ok until i replaced it w/a 32/36 weber(carbs direct).
i have to keep my stock stuff for a bi-annual smog game.
i'm real pleased w/the weber, but i've always had a soft spot for them.
the rochester adaption sounds interesting.
limited(dual 750 cfm dp's) holley experience.
side drafts also sound interesting.
