need to change clutch
  • 11 Replies
  • 1946 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« on: December 27, 2008, 01:49:41 PM »
on a 87' sammy is it easier to drop the tranny or pull the motor? how long should it take? any thing i should get other than the clutch kit   this is not the first one that I've done just the first in a sammy
Re: need to change clutch
« Reply #1 on: December 27, 2008, 02:07:10 PM »
I'd just drop the tranny......easy to do and can be done by hand (remove the intermediate shaft, remove the engine to tranny bolts/nuts, take out the rear tranny mount bolts, unhook the backup lights and 5th gear switch connectors, lay under it, lift it up slide it back and drop it out).
Make sure the clutch kit comes with a replacement throwout bearing and pilot bearing.....if it doesn't, get them.
I'd replace the rear main engine seal while you're in there....easy and cheap to do.
Make sure to have the flywheel turned too.
I'd figure on a half day to full day, as a good estimate.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #2 on: December 27, 2008, 02:36:57 PM »
thanks
« Reply #3 on: December 27, 2008, 03:12:05 PM »
I tried to drop the box on my 413 and couldn't get it out, I ended up pulling the motor.
« Reply #4 on: December 27, 2008, 03:35:59 PM »
I think I had to remove the starter motor too, but... yeah, wasn't that hard. Much easier if you have a friend.
« Reply #5 on: December 27, 2008, 04:29:59 PM »
Yeah, the starter (or at least the 2 starter bolts) has to come out too.
There is a trick to make dropping the tranny easier......search for "notching transmission crossmember" and it will explain and possibly even show some pics.....if the info isn't on here it is on zuwharrie.
Offline ROSS
  • 1412
« Reply #6 on: December 27, 2008, 04:54:41 PM »
you have to remove the shifter also.  and get a allignment tool
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #7 on: December 27, 2008, 04:57:17 PM »
it looks like i can take the stick off than slide it back and out      how heavy is the tranny
i get to do this out side in the rain wohoo  at least the snow in gone:)
Offline RHodge
  • 523
« Reply #8 on: December 27, 2008, 07:00:42 PM »
the trany is light I started to use my trany jack but it wouldn't fix, I was supprised about how light it is maybe 50 -60 lbs
« Reply #9 on: December 28, 2008, 11:19:42 AM »
The tranny can be "bench pressed" out (unless you are a small "stick boy"). ;D
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #10 on: December 28, 2008, 05:43:25 PM »
I am a stick   but but put a NP435 in my f250 by my self weeks ago  i think i can handle this tranny just wanted no surprises on the weight
Offline Merlin93
« Reply #11 on: December 28, 2008, 09:38:14 PM »
There are two seals that you should replace, or at least examine, while it's apart: the engine rear main seal behind the flywheel and the shaft seal at the front of the transmission. Mine was leaking oil from the tranny and dripping out onto the driveway. I though it was the rear main seal, but found that the transmission front seal was almost brick hard! If the clutch lining rivets are already dragging on the flywheel, you may have to have that resurfaced.
