block drain hole???
block drain hole???
Eden1
73
block drain hole???
December 23, 2008, 08:12:42 PM »
1.6 8 valve..Is there a drain hole on the block for this motor,im hooking up a circulating coolant heater ,and this is where it tells me to put it.or is there another way to do it.
mrfuelish
2862
13
you must have a perception problem.
Re: block drain hole???
December 23, 2008, 08:55:08 PM »
In the heater line, just leave your heater switch(cable) in the heat position.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
