Longer wheel studs?
Longer wheel studs?
fordguy79
494
8
long beach Wa,
Longer wheel studs?
December 15, 2008, 08:00:24 PM »
Lot of the wheel studs r messed up on my 87' sammy from the last owner I've been replacing them slowly with stock style but i want to get longer studs so i can run alloy wheels
Has any one done this ?
87sami 32" bfg mt 6.5:1 w/reverse S shifter 1.6 16v sold and missed
idaholwb
772
2
And that's the way the metal crumpled!
Re: Longer wheel studs?
December 15, 2008, 10:45:07 PM »
you should be able to find them at your local auto parts wholesaler. Have them look up the correct ones and try to match up the longer ones, maybe 10mm longer.
97 Sport
265/70-16s
2" lift
2.0 swap
Skyhiranger
3734
122
I don't buy, what I can build
December 21, 2008, 07:00:20 PM »
Ummmm, you shouldn't need to use longer studs to run alloy wheels (at least I didn't). FYI, stock samurai front wheel studs are longer than the rears, so that is an easy way to get longer rear studs, for whatever reason.
mrfuelish
2862
13
you must have a perception problem.
Reply #3 on:
December 21, 2008, 11:05:36 PM »
They do make a longer lug nut for mags.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
Drone637
8121
116
Evil Cow
Reply #4 on:
December 22, 2008, 12:06:01 AM »
Get some from the front end of a Geo Tracker. They are a bit longer then the stock studs for a Samurai.
fordguy79
494
8
long beach Wa,
Reply #5 on:
December 22, 2008, 05:01:05 PM »
Thanks for all the info
