Just picked up an 82 sj410 tintop in not bad shape. After using the search function I still have a few questions. What would the stock diff gear ratio be? Does the 82 transfer case have the lower gears that you can swap for a samurai t-case? I also have an 88.5 samurai so was wondering about the t-case swap for lower gearing. I also have a 79 lj80, what would the diff gear ratio be in that? Thankful for any info you can provide. Thanks.
