rocker repair?
  • 3417 Views
Offline rascott
  • 669
  • 15
rocker repair?
« on: December 07, 2008, 07:07:48 AM »
i'm repairing the rocker panels on my sidekick.
my doors still open ok, but i think another season would finish it off.....
<a href="http://s301.photobucket.com/albums/nn56/rascott_2008/?action=view&current=PB260136.jpg" target="_blank"><img
also trying to figure how to post pics. any suggestions?
so far, i have opened it up to see what's in there, gathered some materials, and have begun making brackets and braces.
i will post more pic links, since that is the only way i know.
Offline MacZuki
  • 53
Re: rocker repair?
« Reply #1 on: December 07, 2008, 09:49:41 AM »
post the IMG code in your photobucket, NOT the HTML, Its the next one down.
and the picture will apear here
Whats That ?
Well then go get your tow strap, and Ill be happy to take You and your Jeep to places you've only heard about.
Re: rocker repair?
« Reply #2 on: December 08, 2008, 12:02:31 AM »
You are right, there is not much time left (or metal either) to repair your rocker panels.
I replaced my rocker panels with 2X4X1/8" tubing.  This is how I did it.
http://www.zukiworld.com/forum/index.php?topic=22395.0
This is what the rock panels look like now.
« Last Edit: December 08, 2008, 08:18:20 AM by BRD HNTR »
Re: rocker repair?
« Reply #3 on: December 08, 2008, 04:26:32 AM »
What, they're not supposed to look like that?  ;D ;D
Offline rascott
  • 669
  • 15
Re: rocker repair?
« Reply #4 on: December 08, 2008, 06:03:35 AM »
thanks for the photo tip- gonna try it here.
if that worked, things are looking a little different.
oh!oh! it worked! i have to organize a couple of more pics.
« Last Edit: December 08, 2008, 06:08:16 AM by rascott »
Re: rocker repair?
« Reply #5 on: December 08, 2008, 08:21:17 AM »
I wish my changes were that fast.  Is that a photo repair, or what did you use.
Offline rascott
  • 669
  • 15
Re: rocker repair?
« Reply #6 on: December 08, 2008, 09:34:20 AM »
no photo shop there- i'm too much of a luddite for that(kudos to MacZuki on the posting help!).
i did this much yesterday.
your repair thread spurred me on!
i'm using 2" square tube and bracing it up to the sill(inside) and to the floor pan.
i still have to finish the bracing and then plan to seal it back up.
duplicating the pieces as i go along should make the other side easier.
suzi the psychic is my fishing rig- she doesn't mind my welding- i'm using one of those cheap harbor freight flux core wire feeds.
thx to Rinoman for getting my photo posted- you must be a wizard.
Offline rascott
  • 669
  • 15
Re: rocker repair?
« Reply #7 on: December 13, 2008, 03:02:40 PM »
finally finished the passenger side.
made some braces(3) to try and tie the tube to the door sill and floor pan.
i think those, plus the front/rear braces, could keep it in place. mabe.
then i sheeted it back up with the stuff i had cut out.
front brace
rear brace
that's all i'm doing to her on this side(for now)
i may wait a while on the driver's side. it's not as bad, but this was a bit of a pia. i'll go scrub this one a bit and see how it does........
Re: rocker repair?
« Reply #8 on: December 20, 2008, 09:20:38 PM »
You can do a lot with those little wire feeds, once you get used to adjusting temp and speed.
The new rock rail will be much more effective than the old rock panel.
