front or rear tj springs?
  • 1183 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: November 26, 2008, 08:28:53 PM »
in a 4door tracker, what tj springs would you install, front or rears?  would 4 to 6 cyl make a difference?
Re: front or rear tj springs?
« Reply #1 on: November 27, 2008, 07:43:59 AM »
Where are you putting them, front or rear of your Tracker? Neither will work on the front of a Tracker, but I've heard of some guys using the rear jeep coils in the rear of a Trackick. They are slightly bigger in diameter and a few inches longer, which is what provides the lift. You'll most likely have to modify your coil mounts to fit the jeep coils larger diameter.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: November 27, 2008, 04:46:38 PM »
they would be for the rear.  have some xj springs, hear they give quite a bit of lift.
Offline idaholwb
  • 772
« Reply #3 on: December 02, 2008, 10:33:51 AM »
 TJ fronts are going to give about the same amount of lift.
97 Sport
265/70-16s
2" lift
2.0 swap
