How strong is a 10 bolt rear?
  • 1193 Views
Offline CG98x
  • 38
« on: November 25, 2008, 11:06:06 AM »
I broke my aluminum front third member and decided to go ahead and upgrade to 5.13's and do away with the front air disconnect since I was having trouble. I thought I was buying a rear third out of a 1994 sidekick which I was led to believe would be a 12 bolt. i've got it and it is a 10 bolt should I be concerned about breaking it?
thanks
1999 Vitara 2.0l 5 Speed. 2 inch body and 2 inch suspension lift. 215/85/16 Capital AT's. Custom bumpers and a few other things 5.13's and no air diff.
Offline Frank84
  • 176
Re: How strong is a 10 bolt rear?
« Reply #1 on: November 26, 2008, 05:53:32 PM »
Somebody will correct me if I'm wrong, but I believe a '94 10 bolt would be for a 22 spline axle.  You'd need a 26 spline diff for the newer tracker/vitara which came on '96 and later models.  You can count the splines inside the spider gears (where the axles slide in) on your 10 bolt diff to be sure.   I think the spline count thing applies both front and rear.
Also, I don't know that a 10 bolt diff would slide over the 12 studs on your axle casings anyway - unless you're swaping the cases as well.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline CG98x
  • 38
« Reply #2 on: November 27, 2008, 05:27:56 PM »
It's already in there so I know everything matches up. The 10 and 12 bolt zuki diffs refer to the number of bolts on the ring gear. I'm thinkin all sidekicks had 26 splines in the rear. I was led to believe that 93 and up would have a 12 bolt carrier. Its only 8 studs that hold the 3rd in place. I know it fits and works but I'm wondering about the strength.
Thanks
Offline JayInBarrie
  • 107
« Reply #3 on: November 27, 2008, 06:23:33 PM »
Thanks
Your right.
Good question..  Maybe they may know in the Sidekick forum.
You have the 2 door, yes???
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
Offline CG98x
  • 38
« Reply #4 on: November 27, 2008, 09:11:00 PM »
Nope it's a four door
Offline gravity_powered
  • 43
« Reply #5 on: November 28, 2008, 11:35:37 PM »
I've heard a rumor that all the carb models had the 10 bolt and all the EFI had the 12 bolt, dunno how true it is though.....
'98 2.5 V6 Grand Vitara
TJM Bullbar
Lightforce 170 driving lights
Wombat Racks roof rack
235/70/16 Toyo Open Country A/T
