Tracker Torque Converter removal
  • 961 Views
xoloski
« on: November 12, 2008, 01:46:11 PM »
I want to mount a 1.6 to an engine stand but the torque converter is still attached to the flex plate by three bolts / nuts.
I tried a 3/8 drive 14mm socket and broke the socket.
What's the trick to removing the nuts / bolts to get the converter off?
Offline Armour
  • 360
Re: Tracker Torque Converter removal
« Reply #1 on: November 12, 2008, 04:38:44 PM »
There should be no trick! Mine came out wuth no problem. I would say try again! Heat the nuts if you have to!
