Front lower shock mounts
  • 1693 Views
Offline cstello
  • 33
« on: November 11, 2008, 07:28:49 PM »
I found a broken front lower shock mount on my sammie today. Where can I get a replacement? I believe its the stock one.
Offline heiney.5
  • 175
  • 9
Re: Front lower shock mounts
« Reply #1 on: November 12, 2008, 04:45:39 AM »
I dont know about "stock" mnts....But sky makes some nice weld on ones. They seem pretty reasonable to me.... I bought mine from Lowrange (scroll down):
http://www.lowrangeoffroad.com/samsuspparts.htm
Or you could buy direct from Sky, either way. I'm sure there are lots of other companies out there that make different tabs that could be used for shock mnts, ie Ballistic/etc.
« Reply #2 on: November 12, 2008, 06:18:16 AM »
If it is stock try Hawk :o I should have been a famous rapper! 1-888-Samurai.
« Reply #3 on: November 12, 2008, 09:13:20 AM »
If you check with your local ford dealer, you might be able to get the old F-250 shock mount towers.  Then just convert to a longer shock.  :)
« Reply #4 on: November 12, 2008, 05:05:36 PM »
FYI I have seen the Ford towers rip the frame. You have to be very careful when welding them on.
phloop
« Reply #5 on: November 12, 2008, 06:35:20 PM »
Good idea as soon as he fixes the lower shock mount.
« Reply #6 on: November 12, 2008, 10:34:48 PM »
Ha, I didn't even notice that he broke a lower mount.  That was rather silly of me...
Just get a long bolt the right diameter, cut the head off and weld it into your spring pad.  Problem solved and it's already threaded.
