Hydraulic clutch conversion
  • 2039 Views
Offline MKOLSEN22
  • 217
  • Come on 32's
« on: November 02, 2008, 11:57:24 PM »
I've had some trouble with my clutch cable not being able to keep its adjustment. This started about a year ago when the firewall fatigued and spider web cracked after almost 200,000 miles.
Well after looking around I found
and
and I decided to see if I could change things from a cable to hydraulics. Well, after an all afternoon thrash fest yesterday I have it completed and I'm glad to report that it works very well. Here are some pictures of the installation.
And a few of the hydraulic line routing
Access to the reservoir on the mastercylinder is very limited and I had to notch and weld in a reinforcement plate in hte knee bar where the master/pedal assembly are mounted, but it was worth all of the trouble. I can now shift gears with out grinding and it should not loose its adjustment like the cable did after the firewall fiasco.
I still have a few loose ends to tie up, but for now my daily drives will be a lot more relaxing for both me and the tracker transmission.
Mike
« Last Edit: November 03, 2008, 12:03:16 AM by MKOLSEN22 »
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
Re: Hydraulic clutch conversion
« Reply #1 on: November 03, 2008, 05:16:31 PM »
do you have part numbers and stores where you got the parts
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #2 on: November 03, 2008, 08:39:10 PM »
The pedal came from Chassis Shop Performance Products and here is a link to their web page:
http://secure.chassisshop.com/partdetail/272-S-3-4/
I tried to order the slave cylinder fom them as well but they were out of stock at the moment. Instead I ordered it from Speedway motorson the following web page
http://www.speedwaymotors.com/p/783,38_Universal-Pull-Type-Slave-Cylinders.html?itemNo=slave
Both of these items are stock CNC Controls items and can probably be found at a variety of other vendors, especially ones that service the sand rail market.
Let me know if I can answer any other questions.
Mike
