Help! Ghost oil leak!
  • 17 Replies
  • 3613 Views
Offline Fordota
  • 40
Re: Help! Ghost oil leak!
« Reply #15 on: November 03, 2008, 01:00:16 PM »
I hear ya
« Reply #16 on: November 03, 2008, 09:50:50 PM »
u can also try adding motor honey
Offline idaholwb
  • 772
« Reply #17 on: November 03, 2008, 10:00:20 PM »
 Avoid using motor honey in Suzuki engines unless you plan on replacing the engine within the next couple months at the latest. They need a normal to thinnish type oil. They can't handle the heavy viscousity.
 Have you tried replacing your PCV valve? A lot of times it can be the simple little thing over looked for oil consumption. They only cost around $6 or $7 at a parts store for the 8V engines. The 16V costs as much as $15 from what I can remember. Try that.
 If your engine seems to have a ghost leak that appears to be from the rear main, more than likely it isn't. The more probable culprit is the distributor housing O-ring. The only ones that I have found that don't break down over a few months is a factory Suzuki O-ring. They are less than $1.
97 Sport
265/70-16s
2" lift
2.0 swap
