waterpump lifespan
  • 1105 Views
waterpump lifespan
« on: November 01, 2008, 05:40:36 PM »
I have a 96 sidekick with 60K on the clock. I am about to replace the timing belt and I am wondering if I should replace the waterpump while I am at it. The FSM does not list this as a maintenance item so should I hold off until 120K or just go ahead and replace it? What is the lifespan of the water pump on these things?
Offline bbagwell
  • 278
Re: waterpump lifespan
« Reply #1 on: November 01, 2008, 11:14:47 PM »
I would replace it.  It is probably fine, but as long as you are going to all that work to replace the timing  belt you might as well replace the water pump at the same time.
2002 Suzuki Grand Vitara
1983 Toyota PU
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #2 on: November 02, 2008, 05:08:50 AM »
What he ^ said. If I do a water pump I do the timing belt also, and vice-versa.
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« Reply #3 on: November 02, 2008, 05:39:49 AM »
same here if you are going that far you might as well do it.  Think of it as a insurance policy.
Offline Cuthulu
  • 384
« Reply #4 on: November 02, 2008, 07:23:40 AM »
I did my timing belt at 90,000 and did the water pump too.  It was pretty easy since I had it apart already.  Also the one I got from Hawk looked to be better quality then the the factory one.  Anyway it's an easy swap since you already have it exposed, it only take like another hour.
« Last Edit: November 02, 2008, 01:27:17 PM by Cuthulu »
