After the Grand Vitara Body Lift
  • 11 Replies
  • 5791 Views
Offline Mugwui
  • 8
« on: October 21, 2008, 04:07:32 AM »
Can anyone tell me how to refit the front and rear bars after the 2" body lift to my 99 GV LWB????
is there a custom mod that needs to be done or is there a simple trick that is staring me in the face.
If possable some pics would be great.
Also, does the toursion bar in the engine bay need to be refitted or can it be left off?
and is there anything else I should be doing?
99 GV LWB, 2" Body Lift, 2" Lovells Suspension, Custom Strut & Shock Extenders, 31x10.5 MT 117 Extremes, 15x7 Rock Crawlers.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: After the Grand Vitara Body Lift
« Reply #1 on: October 21, 2008, 06:52:01 AM »
Mugwi, if you are referring to your front sway bar:  http://www.zukiworld.com/forum/index.php?topic=20143.0
If you are referring to yiour pan hard bar in the rear, with two inches of lift, I don't recall anyone having to extend it.
Offline bzzr2
  • 1011
« Reply #2 on: October 22, 2008, 06:52:31 AM »
cut and re-weld the stock mounts up 2inches higher or just leave them off.  strut brace should be remounted, i had to do a little trimming inside the fender well so it would fit back on.
09 taco reg cab short box 4x4
Offline Mugwui
  • 8
« Reply #3 on: October 22, 2008, 03:57:36 PM »
thanks, I was talking about the strut brace... The big old bar that straddles your engine from strut to strut...Do you need it or can it be thrown away along with the sway bar.
Offline Trackerprts
  • 106
  • Aiirbag
« Reply #4 on: October 22, 2008, 07:17:42 PM »
NO!
It is a structural member !
I just beat down the inner fender so it will fit in you may need to jack up the car to reinstall it.
99 Tracker pieced together out of 3 cars.             RR Body and suspension lift ,31 10.5r15
winch bumper,rock sliders
Offline blacknight
  • 987
    • Gonzookin
« Reply #5 on: October 23, 2008, 06:02:29 AM »
Here's my XL-7's strut brace  post BD lift
Offline olija
  • 770
    • Check out my cardomain
« Reply #6 on: October 28, 2008, 08:19:51 PM »
What do you guys do around the shifter area when you have a body lift? On my Sidekick I had a body lift and I ended up removing the plastic console and bolting an S-10 shifter boot into the floor because the stock rubber accordion boot was binding. I am talking about 5 speed models obviously, automatics probably don't have this issue.
Offline bzzr2
  • 1011
« Reply #7 on: October 29, 2008, 06:54:45 AM »
i had to cut the bottom of the plastic box around the shifter to get 2, 4 & R, otherwise the shifter hits the plastic, then i just installed a cheap after market non rubber shift boot.  looks ok and works.
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #8 on: October 29, 2008, 10:16:44 PM »
Yup...I just cut out some of the bottom edge of the plastic trim under the boot, put in a few screws, then stretched the OEM boot over the head of the screws.  Doesn't look too bad, really.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #9 on: October 30, 2008, 08:23:45 AM »
Fuck thats ugly .
Are people interested in having a new strut tower brace made for the body lifts?
Next summer ill be building new strut braces also to clear the 2" body lifts if anyone is interested?
01 GRAND VITARA
Offline bzzr2
  • 1011
« Reply #10 on: October 30, 2008, 12:59:43 PM »
 :P bush trucks aren't supposed to be pretty, it's been a while since you've seen mine up close, man you wouldn't believe how ugly it's gotten!
Offline JDMCRX
  • 1110
« Reply #11 on: November 01, 2008, 06:07:54 PM »
LOL there is ugly and hack :P.
01 GRAND VITARA
