1999 GV Keyless Entry
  • 1148 Views
Offline fullsink18
  • 250
  • Wheel Me!
« on: October 09, 2008, 10:18:09 AM »
Just got a 1999 GV to a DD and I found it has a keyless entry system and I found one of the key fobs in the glove box.  Got some instructions programed the fob.  The remote or system does not seem to work very well.  I have to hold the fob next to the under dash box for it to work.  So I figured bad battery in the fob replaced it and no better.  I seen a black wire coming out of the box and figured that is the antenna (kind of short), not sure if that is how they all came or what.
Any ideas on what to do?  New key fob?
Thanks
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline Novadon
  • 205
  • South Carolina. USA
Re: 1999 GV Keyless Entry
« Reply #1 on: October 09, 2008, 12:07:05 PM »
It COULD be the fob, but they don't have a very long range capability to begin with. I can get 2-3 car lengths.
New and used fobs are all over e-bay, and luckily ours IS programmable unlike the years starting right after.
03' Honda Odyssey
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #2 on: October 12, 2008, 10:10:42 AM »
The system is weak.  I've gone through a few factory remotes in my 1999 GV, and use an aftermarket one now (it isn't much better).  All require you to be within a few feet of the car.  I think it's a combination of the remotes being weak, and the receiver in the car being weak as well.  I usually have to hit the button several times at different angles and positions before the doors unlock.  What's the point of having the remote?  I'm sure the newer remotes (2003+) are good.  Our 2005 Suzuki Aerio has incredible remotes.  I bet they work from 100 feet away or more.  Good luck.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
