GV front diff broken
  • 1302 Views
« on: October 06, 2008, 12:50:54 AM »
Hi all,
I am owner of GV 3 door LHD 2001 with J20A engine, and I have front carrier aluminium broken.
I want to replace it by a more solid carrier.
therefore the steel axle of 2.0L TD Vitara 5 door it is compatible with my front drive shaft RH and shaft front drive ( in housing differential ) ?
thank you.
Giacomo
Offline Frank84
  • 176
Re: GV front diff broken
« Reply #1 on: October 07, 2008, 06:03:34 PM »
While I'm not familiar with the diesel, I'm 99% sure the answer to your question is YES.  The steel assembly is bolt in for the aluminum and the axle shafts will transfer.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline IanL
  • 466
« Reply #2 on: October 08, 2008, 01:06:16 AM »
Make sure you have the right gears to match the rear!
« Reply #3 on: October 08, 2008, 01:16:19 AM »
thank you
but differential ratio   them is the same one? 4.875 or 5.12 ?
Giacomo
