05 Forenza Vacume leak HSSsss
  • 2599 Views
« on: October 01, 2008, 04:03:00 PM »
Hi , Today our check engine light came on (again) . Auto zone said code was " vacume leak" . When opening the hood , We could hear a hssssing noise (U know like air being pulled though small hole ). But after following/checking all hoses for leak we could not find ANYTHING ! Anybody had this dilemma B4 ? My neighbor ( his is auto mech.) Said to " check EGR devise ? any opinions ? Help . JIM
Offline Armour
  • 360
Re: 05 Forenza Vacume leak HSSsss
« Reply #1 on: October 01, 2008, 09:10:18 PM »
If you hear the hissing noise then just keep looking! It will be there somewhere!
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #2 on: October 01, 2008, 09:30:44 PM »
Take a length of hose put to your ear and probe around everything from the throttle plate to the block. and listen 'till it gets loudest. could e a gasket. could be a hose anywhere from the brake master cylender to the evap system to the heater controlls under the dash. follow the sound. You can also apply propane/ any flamable gas and when put near the leak your idle will jump. be carefull.  cheers   NMc
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
