95 sami transfer case probs
  • 1628 Views
« on: September 30, 2008, 10:55:51 AM »
Hey guys I am new here and a new sami owner. Don't know alot about suzukis so I thought I would come here and ask. When I first got this 95, the transfer case would not shift. just real tight and would not change. Then I finally jacked with it a bit and now it is stuck in never never land. It will go in reverse but thunks, forward gears sound likke they are not engaging completely. Took the assembly off and cannot move the shifter at all even with it out.  As I rotate the rear shaft I hear the front shaft begin to try to engage but doesn't. Drained the fluid and it smells burnt. Any thoughts? I appreciate the help.
Re: 95 sami transfer case probs
« Reply #1 on: September 30, 2008, 12:42:04 PM »
Is it a 1995 Samurai or a Tracker?
« Reply #2 on: September 30, 2008, 01:29:01 PM »
samauri
« Reply #3 on: September 30, 2008, 01:34:40 PM »
Nice, we don't get many that new...
It sounds like your t-case is stuck in neutral.  With your shifter pulled out can you use a large screwdriver to move the shift forks manually?
« Reply #4 on: September 30, 2008, 05:59:14 PM »
not in neutral, and after changing the fluid I can get the shifter to move to the various gears. But there is slack and the forward gears grind a bit when you let out the clutch. the reverse does engage and does not grind. the slack is in the front diff. coming from the transmission.
« Reply #5 on: September 30, 2008, 06:06:23 PM »
oh yeah,  the shifter would not pull out of the transfer case after removing the container and the spring.
Offline ROSS
  • 1412
« Reply #6 on: September 30, 2008, 07:31:41 PM »
SHIFTER SHEET
« Reply #7 on: September 30, 2008, 10:32:14 PM »
Your bearings could be going out also,Those have sealed bearings in The later models If I remember correctly, the Gear oil is just for the Gears That Year.
« Reply #8 on: October 01, 2008, 09:20:32 AM »
SHIFTER SHEET
That could cause the shifting problem, but even with a bad sheet he should be able to pull the shifter out without any issue.
Actually, I can't think of a good reason for the shifter to not be able to pull out...
